What coil for Prestolite electronic distributor?
pschauss
Post by pschauss »
I got half way across the bay this morning when my port engine quit on me. (It was the starboard engine last time, about a month ago.) By the time Seatow got me back into my slip, I was able to restart the engine so I am suspecting a problem with the coil or the electronic ignition module. The sticker on the distributor says "Prestolite IDU 7801BS". The coil says "Delco Remy" and has a number on the side which looks like "1061". I googled it, but cannot find anything on that part number.
Do I need a ballasted or unballasted coil?
I'm getting my money's worth out of my Seatow membership. The guy who towed me knew exactly where my slip was.
Peter Schauss
Water-Lou
scot
Re: What coil for Prestolite electronic distributor?
Post by scot »
I had coil problems a few years back. Standard coils tend to "soak" over long output cycles. Mine would run fine, then not idle or restart easily.. let it cool down a while and all was well. I went to a high performance coil (MSD Baster) and the problems went away.
On the ballast, do you have a ballast somewhere in the ignition wiring, or is one built into the distributor?
Good luck
I used one of those yellow super coils on my Chryslers
pschauss
Post by pschauss »
On my port engine, the voltage at the + terminal of the coil is about five volts with the ignition on and engine off. On my starboard engine- different distributor - it is about twelve volts. My starboard engine has a ballasted coil. Based on the measurements I took it looks like I need an unballasted coil on my port engine.
Peter Schauss
Water-Lou
Joseph Fikentscher
Post by Joseph Fikentscher »
Users browsing this forum: No registered users and 75 guests
