I see that the factory lists the b31 at just over 10k lbs. I have a hard time believing this. Seems too light.
I am trailer shopping and found a good deal on a near new trailer rated at 16,500 gvw. Boat is a standard fbc model with Yanmar 315s. Can anyone give me some measures weights of comparable boats?
Actual Weights
Re: Actual Weights
My 62 Express has a factory weight of 11,500lbs
With 440 gassers and tank of fuel 162 gallons the Travel Lift measured weight at 14,000lbs
Re: Actual Weights
Carl,
When you guys say weight out of the factory door, is it with or without engines? Fuel? Water? Anchor and chain?
Thanks.
Thanks.
Re: Actual Weights
Out the factory door should be with all standard equipment including standard engine package.
Re: Actual Weights
Thanks Tony,
I understand with engines but without any fluids. Perhaps minor gas quantity for engine factory testing.
Users browsing this forum: Bing [Bot] and 388 guests
