Hello All ,
Long time since I've been on here .
Looking for info on where to get a helm pump rebuilt.
I'm in Hyannis , Mass.
Was also looking at the rebuild kit . Is that an easy job ?
It's is my outer O Ring towards the shaft that is seeping fluid .
Jack
Hynautic H50 rebuild
Re: Hynautic H50 rebuild
Buy the Kit and do it yourself. Very easy to,if you have device to take pictures, makes it simpler. “O” Rings, Seals, and all mating surfaces must be clean.Lightly lubricate all parts during re-assembly. Have done it a couple of times, not hard at all.
EarleyBird
EarleyBird
Contact Rose Marine in Glouster, MA they have all the parts you need.
It's not hard at all but there is a caviat.
Helms that are mounted vertical allow water to run down the shaft to the face of the helm. Many times there is a wood backing to support the helm. That wood gets wet and remains wet.
All that moisture can cause corrosion between the aluminum body and stainless shaft.
Inspect carefully at the shaft seal location.
A few helms over the years had enough corrosion that a new seal would not seal into the body.
Just check if doing yourself
Thank you all for your help. Im going to inspect it and do the rebuild if it all looks good.
Users browsing this forum: Google [Bot], mike ohlstein and 114 guests
