What is this?
pschauss
What is this?
Post by pschauss »
I have one of these on each side. Part of the one on the starboard side is broken off.
http://www.ipernity.com/doc/307687/47364682
thanks,
Peter Schauss
Water-Lou
Snipe
Re: What is this?
Post by Snipe »
Looks like an out rigger mount.
Jason
Seapalm
Re: What is this?
Post by Seapalm »
Or Antenna mount.
Fairing block used to plumb any type of hardware/attachment.
Should be easy to remove if not in use.
"Some of its Magic, some of its Tragic", Jimmy Buffet
Bertram 35 "SeaDuction”
Bertram 31 Project
Bertram 25 Project
Bertram 20 Baron Project
Florida Panhandle
mike ohlstein
Re: What is this?
Post by mike ohlstein »
Outrigger mount. That's where the arm and clamp were, which held the Lee Jrs in place while under way.
Mean Team Leader
PREDATOR
Burn Oil
Eat Food
1973 FBC 1286 0273-315
Re: What is this?
That is exactly what my mounts are bolted too.
Re: What is this?
Post by Pete Fallon »
Pcshauss,
The wooden fairing block is where the outrigger was mounted to, you can see part of the old outrigger on the side deck in the bottom of the picture. The corroded part on the side of the Fly Bridge house looks like an old VHF antenna base without the ratchet, looks like someone moved your grab rail forward hence the back mount is an inch forward of where it should be, or someone replaced the original Perko grab rail with a stainless steel unit. The original Perko grab rail mounts had a longer body and were mounted from the back side under the fly bridge and cabin house top, pipe was held in with set screws on the bottom side.
pschauss
Re: What is this?
Post by pschauss »
Does anyone have a picture showing how all of these pieces fit together?
Peter Schauss
Water-Lou
Users browsing this forum: Bing [Bot], Google [Bot] and 99 guests
