Lifter tapping/Valve tapping
I was leaving this past holiday weekend on my 28 Bert when an hour in the trip I heard tapping coming from my starboard engine, comes and goes. Not sure what it was, gauges looked good. I slowed down to check, its sounds like 1 of my valves or lifter is tapping. Is there a easy fix for this?? I have read some have used a product called seafoam to clean lifters/valves. Does this product work, would it hurt to try ? any suggestions And will I hurt motor if I continue to run it ? The motor is a 1989 350 270hp crusader with carburetor. Thanks Mike
Re: Lifter tapping/Valve tapping
If its a collapsing lifter, could throw a push rod and just lose a cylinder. If it's crud built up on a valve stem, valve could stick open and hit piston. A spring issue could lose a keeper and drop a valve into a piston.
You can try an additive in the fuel and oil.
Bruce thanks for the reply. So to be safe I should get new lifters/rods ? Thanks Mike
Bruce is correct. You never know if it is just dirt or something else.
When I had the big blocks I had a noisy lifter. I used the old method of putting a quart of transmission fluid in the engine then let it get hot and changed the oil. It stopped the noise. So in my case the sticky lifter was probably dirt. But if it did not clear up I would have been changing lifters.
Marvel Mystery Oil worked great for me--pour it down the carb at idle, let the smoke come out the exhaust, shut it down and leave it overnight--dissolves the carbon on the valves.
Users browsing this forum: No registered users and 257 guests
