Waste pump
Waste pump
I am redoing my holding tank and adding a yellow Gusher pump.
Can anyone take pictures of their original systems layout.
I have a 1986 28 flybridge.
Email: don_rich@sbcglobal.net
Re: Waste pump
Don,
I sent you an email with picture. If this is what your looking for and need more detailed pics, let me know.
Cheers,
Jonathan
Cheers,
Jonathan
Re: Waste pump
Thank Capt. John.
I just bought a new old stock one for $50 last week.
Re: Waste pump
Jgreen,
I could use some more pictures of hose routing to and from the tank, toilet and the manual pump if you get time.
Re: Waste pump
If any one is working on their 28 Bertram (vintage 1983-89) could you take some pictures of the overboard holding tank discarded pump the yellow manual one . I need the routing of all the hoses from the toilet to the holding tank including thru Hull and y valve.
My email is don_rich@sbcglobal.net
Don
Don
Re: Waste pump
DonDonmystic1 wrote:If any one is working on their 28 Bertram (vintage 1983-89) could you take some pictures of the overboard holding tank discarded pump the yellow manual one . I need the routing of all the hoses from the toilet to the holding tank including thru Hull and y valve.
My email is don_rich@sbcglobal.net Thanks Don
Not sure what type of rush you are in, but come spring when we open up the boats after the winter is over, I could try and get pics of my friends set up in his 28. Hopefully someone can help you out before then. He usually does not cover until late April, since he is usually in Florida the later part of April.
Re: Waste pump
Don, where is your holding tank?
Also, where is your through hull intake to the toilet?
Generally speaking, you can do as you feel in terms of how you will accommodate your new piping, you don't have to follow any predetermined pattern.
