Replacing an oil pressure sensor (Mercruiser 454)
pschauss
Post by pschauss »
I bought a new oil pressure sensor for my port engine because the oil pressure gauges for that engine (both upper and lower stations) are reading about 40# with the engine off. With the engine running, the gauges are pegged. It looks like it should be a simple matter of unscrewing the old one and installing the new one. Do I need any special sealant when I install the new one? Anything else that I have missed?
Peter Schauss
Water-Lou
Kevin
Re: Replacing an oil pressure sensor (Mercruiser 454)
Post by Kevin »
I just swapped mine. Cleaned threads and appeared to be old tape or sealant on them. Put a wrap of tape on them and reinstalled. No leaks.
Make sure wire connections and or harness connection point are not corroded.
pschauss
Post by pschauss »
What kind of tape did you use? I would be concerned that Teflon tape might melt.
Peter Schauss
Water-Lou
Kevin
Post by Kevin »
I believe it was Teflon tape. Hopefully someone can advise if that is the wrong way to do it. I will keep eye on it as I just did it two days ago.
mike ohlstein
Post by mike ohlstein »
Teflon tape begins to melt at 327° F and will ignite at 500° F. If your engine gets that hot, you have bigger problems to address.......
Mean Team Leader
PREDATOR
Burn Oil
Eat Food
1973 FBC 1286 0273-315
Kevin
Post by Kevin »
Thanks Mike! I should be good.
pschauss
Post by pschauss »
Since the purpose of the Teflon tape is to make certain that you can remove the sensor at a later date, is there any reason I can't use an anti-seize compound instead?
Peter Schauss
Water-Lou
mike ohlstein
There are plenty of good Marine anti-seize products. It's hard to find them in small amounts. But here's one...
https://www.amazon.com/MARINE-GRADE-Met ... B00VM2PZYG
Mean Team Leader
PREDATOR
Burn Oil
Eat Food
pschauss
Post by pschauss »
Thanks for all of the suggestions. Getting at the sensor on the port engine was much easier than had expected. All I had to do was remove the cowling between the engine cover and the port side of the boat.
There was no sign of tape on the old sensor so I just put a thin coat of anti-seize on it.
Peter Schauss
Water-Lou
I have always been told that sensors don't use tape because they need the ground to the block (at least single wire sensors do).
