Headliner
Headliner
Just came across this on one of the Bertram facebook groups. Using a PVC track and canvas for the headliner
https://www.trivantage.com/hardware/har ... &langId=-1
Can't find much additional information but mine will soon need replacing and while pulling a hundred screws to pull down the liner isn't the end of the world, a canvas with a zipper would seem to make a whole lot of sense. Any experience with this?
Re: Headliner
Peter,
A few years back I was in England in a hotel where the bathroom ceiling was probably flaking, so in order to avoid painting every so often they had made a faux ceiling just underneath which was a thin sheet of silicone! stretched out so perfectly that you couldn’t even understand it was not the original concrete ceiling.
So, probably, you could find something similar in the building/hotel restorations type of stores or sites.
Re: Headliner
Not sure how this will work. Looks like the material is stretched with no backing. Only supported across the span by tension. To me that would be a pain, since I see the material stretching in the heat and dampness of a boat and having to be cut and re stretched.
I am in the same situation as you. Time for a new head liner. I am thinking 1/4 inch ply or azek board cut to fit and covered in headliner material, for a place like Sailrite. All this held up by hook and loop.
https://www.mcmaster.com/#hook-and-loop/=1ddzjor
My only concern on that one is, that while easy to take down and put up, will it stay in place when running in any kind of heavy sea.
Re: Headliner
Tony,
The silicone sheet I mentioned (which shouldn't be more that a mm thick) kept the tension by itself, because it was stretched once and for all, during the application.
Furthermore, it does not get affected either by humidity or by the weather.
I tried to find a link somewhere, but you need time...there are so many alternatives.
Re: Headliner
My canvas was put in on a system like that. Only the track is aluminum.
What is nice about it is it just slides right in on top, then a few snaps on the bottom.
Only hitch is with mine the canvas needs to be supported and guided somewhat or it binds a bit...thinking that may be an issue if your intending on having a track secure material from both sides...material would have to go in straight and even from both sides exactly, while the trailing end is supported and coaxed into the track. Not sure it would slide well, if at all if material was taut.
Then again, materials and designs have changed and that may no longer be an issue.
Re: Headliner
Yannis & Carl
My hesitation to using a system like this is taking it down and putting it up. What a pain it could be. I cut hatches in my old headliner years ago. I am up in there all the time since I have some fuse blocks up there as well as wiring connections.
MY old headliner is tired and needs to be replaced. Just need to figure out what will work without causing a ton of issues.
Re: Headliner
Re: Headliner
As they say, pictures are worth a thousand words.
Looks like they place material in track then secure track in place.
Results look good.
Results look good.
Users browsing this forum: Google [Bot] and 34 guests
