New Detroit 8.2 alternator
I pulled the starboard motor alternator out of the boat, and it just tested bad. Do diesel alternators have to be "marine" like gassers? It also has a 3-wire input and single output. Everything the local guy is coming up with has a two wire input. Any ideas? I'll call Johnson Towers tomorrow, but there usual response is that they don't have anything for the 8.2s
Re: New Detroit 8.2 alternator
Think I got it figured out. Thanks
You can probably find help from any good diesel distributor/mechanic to source a starter.
You will find that a lot of the diesel parts are not like gas parts, most are not necessarily ignition protected.
Users browsing this forum: Google [Bot] and 34 guests
