MacDougalls B31
MacDougalls B31
saw this B31 and it’s fitted with something called Zipwake. Went to the website zipwake.com. Looks interesting. Wonder if anyone has ridden the “revival31” and what the thoughts are about this product.
Re: MacDougalls B31
I always thought this was a Volvo system. I remember them coming out with a similar system many years ago.
Re: MacDougalls B31
You’re right Tony - you’re thinking of the Volvo QL interceptor tabs.
http://www.foreandaftmarine.com/VO-QL3841717.htm
They work brilliantly; I’ve always wondered why they haven’t caught on wider. Easy to maintain, nothing protruding, quick acting.
Re: MacDougalls B31
Yes the Volvo Ql Trim Blades. Think maybe Dug installed on Alchemy??Tony Meola wrote:I always thought this was a Volvo system. I remember them coming out with a similar system many years ago.
Couple other companies are making now.
I looked at them before going with traditional tabs...I like that they tuck in. Eliminates problems when fishing or trying to climb back in boat from transom, swimming around transom, backing into slip etc. I also wanted to get low cruise speed lift and blades seemed to be more effective at higher speeds.
Think the two main reason I opted not to use...install required a flat transom surface, more so then tabs, AND I was able to buy traditional tabs at a much better price. Blades were still new to market and pricey...and it killed me knowing just how simple they are to pay twice the price.
At least with regular trim tabs I received several heavy boxes to carry around and open. I got to layout and then mount hydraulic pump, run hoses, I got hydraulic cylinders to mount onto transom, several pieces to the tab to install and mount...run power fill with fluid, check for leaks.
Blades came in a smallish box, spot to install was apparent, make a precision wedge, attach, hook up wires...done.
Re: MacDougalls B31
See what happens when you type slow...someone jumps right in and steals your thunder...
LOL
LOL
- Joseph Fikentscher
Re: MacDougalls B31
Tony, Lars, Carl,
The site says "Discontinued, No Longer Available"
Re: MacDougalls B31
Joe
Which site? I can get on the Fore and Aft and the zipwake site.
Re: MacDougalls B31
Lars
Do you have them installed? I have never seen one on a boat and never heard of anyone using them. Would love to know how well they work. What have they really done for someone? Increase speed, better fuel economy etc.
Re: MacDougalls B31
This whole topic reminded me that I had seen something similar in the past.
This is the Greek version of the vertical blade flap.
It is based on the principle that the rubber, balloon-like contraption, found on top (in red), fills with water (blue) and by expansion it pushes the blade downwards.
You could perhaps make out a few of the technical data, as the units (kg, mm, bar) are in English and the numbers are ...international.
Re: MacDougalls B31
Imtra carries zipwake go here and search it if your interested some of these systems have active type ride control when the boat develops a list it corrects it automatically. I ran boats with these on a bigger scale made by Humphree and they were great. I am also thinking about zip wake for my 31. http://www.imtra.com/zipwake.htm
Jason
Re: MacDougalls B31
Snipe wrote:Iwhen the boat develops a list it corrects it automatically.
One down side is when a boat develops a list its usually for a reason.
Uncle Big Boy decides to go sit on gunnel next to Size of Texas Sally, tabs correct list, is all well and good...nice to have auto correct. I still prefer to request they sit centered or at opposite sides. I'd hate to have to slow down quick going over a big wake, a standing wave only to find boats way off balance and tabs will do squat to correct.
Running and boat lists to one side...no sizable trim in boat this time. So whats up...wind? Not windy...grab co-pilot to take helm and go have a look-Z. Lift side hatch and we see we have a hose that developed a leak, a stuffing box leaking filling compartment with water. Had we not noticed that list, one compartment overflows to next compartment till boat starts running sluggish. Been there more then once.
Kinda the same deal with an automatic bilge at stern without a warning light...pump handles little water leak and you don't notice and keep going. Leak gets worse and by the time you notice that little leak is a big leak and you have lots of water to deal with.
Re: MacDougalls B31
Tony, the foreandaft site. Down the page it says the product is discontinued.
Re: MacDougalls B31
Im laughing my intestins out...
especially in the smaller 28 with a deeper V this becomes a constant attention up at the cockpit.
on the other hand I like to drive in peril
Re: MacDougalls B31
Dr. Pat,
If you have trim tabs now, stay with what you have, a few of the 31's that I have surveyed had that system, If it's made by Volvo it's going to be expensive and you will have to have custom shims made because the 31's transom is not flat she's got a slight curve all the way across. I think Jerry Santiago put them on his 31 FBC with 315HP Yanmars. Like Carl said unless your fishing with a lot of big assed people weight shifting on our 31's doesn't really matter that much.
I ran my 31 Express for 37 years without trim tabs, I did a lot of fishing and didn't want trim tab blades sticking out of the transom that could cut off a fish. When I got my boat back in 1978 she had a set of SLR underwater silencers (instead of internal mufflers) on the transom that stuck out about 10"" off the transom, after loosing a giant Bluefin that ran across the transom they were immediately removed the following day. The boat was louder but nothing stuck out off the stern except fishing rods.
Re: MacDougalls B31
No trim tabs on mine. It didn’t come with them and I read all the posts about them and realized they’re not necessary. I was just wondering about these things and if they were worthwhile and if anyone had any experience with them. Thanks Pete
Re: MacDougalls B31
Priceless wrote:No trim tabs on mine. It didn’t come with them and I read all the posts about them and realized they’re not necessary. I was just wondering about these things and if they were worthwhile and if anyone had any experience with them. Thanks Pete
Once your over 16-17knts with a balanced boat, tabs have little use on our boats.
If playing under that speed, tabs are nice to get the stern up for a slower cruise on plane. For me...a slow economical cruise works best at times. Some family members don't want to be leaping from wave to wave or being shook around. When its getting dark where I cannot see far enough ahead at 18-19knts...dialing it back to 14knts on plane can work. Its that or a 6knt putt putt back to dock after a dock and dine or late night fishing. Sometimes I want to move faster then put-ting along, but don't want to be super vigilant looking for debris in water...Raritan Bay after heavy rains, moon tides can have lots of debris brought in floating around AKA- telephone poles, old docks, pilings, trees, limbs containers, tires etc etc ...so constant watch is more then a must at times.
I ran 15 or so years without tabs before I decided to install. I like, but not required.
Having a flush tab adds that benefit plus keeps stern clear...but comes at a cost.
Re: MacDougalls B31
Raritan bay is a mine field
use to make the run down there in the spring for flounder
1968 hull # 316 - 757
Re: MacDougalls B31
I don’t have them on Alchemy, but have always thought they would be cool.
Skip has the Volvo ones on his 31 Wahine. I am pretty confident he loves them!
D
D
Re: MacDougalls B31
Charlie J wrote:Raritan bay is a mine field
Long run for flounder Charlie...
I'm here and don't even make the run anymore.
I will admit the bay and NY Harbor has gotten much much better the past 10-15 years, but still it has its days were a mine field is a very good analogy.
Heading in from early morning fishing trying to get work with a bit of fog...out of the mist it looked like a forest had been cut down with logs and stumps as far as the eye could see. Took awhile to find a spot I could get through...just glad it was light enough to see and I was going slow enough to stop. Kinda where that slow cruise comes into play.
Re: MacDougalls B31
yea this was years ago
when flounder were still around
only 1 trip a year with a few guys
Re: MacDougalls B31
Even if they were around, its a ride when only allowed 2 fish per.Charlie J wrote:yea this was years ago
Re: MacDougalls B31
trim tabs -----we need no sticking trim tabs all in the prop design. we be needen bow planes like a submarine! i don`t want to push the bow down i want to push bow up!!!!! no Carolina flare on a 31 Bertram why in God`s name would you purposely put the bow into an oncoming wave !!!!
Users browsing this forum: No registered users and 207 guests
