Yanmar 315
Yanmar 315
So I have these 2 motors gears shafts props rudders looks like he was taking salt water in the intake some rust from the valve cover pan.
I don't have time to mess with this stuff any suggestions
Re: Yanmar 315
I'm open to anything they're just sitting here and that's no good
Re: Yanmar 315
Video of motors
https://www.dropbox.com/s/fe8zcva4u3on2 ... 1.mp4?dl=0
Re: Yanmar 315
Keith
If they can be rebuilt and they did not cost you a fortune, I would put them up for sale. Post them here on and on other boards. I would say ebay but they take a good chunk out of the sale.
Re: Yanmar 315
Thank you
Now the 64000 question how much should i ask for them ?
Re: Yanmar 315
If you wanted to double your cruise speed...and ears, you could put in your boat.
Re: Yanmar 315
Nice
Fuel the same ?
Will they fit ?
Fuel the same ?
Will they fit ?
Re: Yanmar 315
Keith
The 315's will fit just fine. Figure on a cruise between 26 and 28 Knots with a top end around 33 knots. This all depends on how much the boat weighs and if you have a tower or not.
Fuel Burn would be about the same as the cummins may be a tad better on fuel.
The only issue would be that everything on a Yanmar is more expensive than Cummins. Filters, parts etc.
Otherwise Great engines.
I don't remember what size Cummins you have, but if they are the 250 or 270's the Turbo is fresh water cooled and on the Yanmars and larger Cummins they are Sea Water cooled. So more upkeep. Turbos need to be cleaned every couple of years.
Re: Yanmar 315
Thank you Tony
250
250
Re: Yanmar 315
Keith...I must have missed a few posts along the way...I thought you were running Detroit 4 bangers.
315's would be a heck of an upgrade to those.
Personally I'd stick with 250 Cummins over 315 Yanmars...but thats just me. I like simplicity.
Re: Yanmar 315
the only draw back with the 315s is the timing belt need to be changed
I think every 1,000 hrs, its not mechanical
other then that I know a lot of people running them and are very pleased
1968 hull # 316 - 757
Re: Yanmar 315
Awesome information gentlemen thank you very much so far I'm very happy with the 4BT
Users browsing this forum: No registered users and 189 guests
