Alarm board's
Alarm board's
Hey guys I put in new alarm boards one of them keep screaming every few minutes any suggestions.
Re: Alarm board's
Keith
When we repowered, I had the same issue with a low oil pressure alarm. When I went searching I found a connection that had worked loose.
The other issue is on the Cummins depending if the board can get wet or not, it might have gotten wet. I believe when JP had the 31, he moved the boards from under the dash to the inside area of the bridge just above the overhead in the cabin.
The other option is to put them in a plastic container.
If they are not getting wet, I would check all the wires to make sure you have good connections.
Users browsing this forum: No registered users and 187 guests
