House battery
House battery
Does anyone have a house battery(3rd)?
Where have you located the extra battery?
If I use an AGM which can weigh between 50-68 lbs.
And fit it with the two existing batteries in the starboard side it will probably cause the boat to list.
I think that I can fit a starting battery
Somewhere near the hold tank on the port side which would balance the boat a bit better.
Re: House battery
aAGM one for port engine one for starboard and two for house/generator exactly in center in companion way between motors . keep heavy weights (fresh water,batteries,fuel ) on centerline of boat no exceptions!!!!!!!!!!!!!
Re: House battery
Don-
For the first several years I owned my boat both Group 31 starting batteries and a Group 24 house battery were located outboard of the port engine.
The boat did have a slight list which was more noticeable when the tanks were light. Other than my annoyance I do not believe there were any serious ramifications.
I now have two group 31 starting batteries and two group 31 house batteries in the center of the bilge between the engines now.
Regards,
Stephan
Regards,
Stephan
Re: House battery
Can you text me a picture of your setup.
Don
870-460-3282
Don
870-460-3282
Re: House battery
Don-
I will try and go to my boat tomorrow for a picture.
Bob Lico has a much more photogenic bilge than I but it looks like the pictures are lost to the Photobucket change.
Regards,
Stephan
Regards,
Stephan
Re: House battery
Don-
I forgot the batteries are out of the boat for the winter but I hope these pictures will be useful to you.
This picture is the bilge between the engines I am standing in the cabin looking aft as I took the picture.
![Image](http://www.scsloan.com/IMG_1284.JPG)
This picture is from a lower angle. The shelf that the battery trays are bolted to is made of two layers of 3/8" Azek laminated with West System epoxy and fiberglass matt. The shelf sits on two mini stringers of Azek bedded in cabosil and epoxy and heavily filleted. The shelf is attached to the mini stringers with 12 large silicon bronze wood screws.
![Image](http://www.scsloan.com/IMG_1285.JPG)
Hope this helps,
Stephan
Hope this helps,
Stephan
Re: House battery
Thanks for the pictures Stephan.
Re: House battery
Stephan
What year and model is your Bertram.
Users browsing this forum: Google [Bot] and 43 guests
