stock 230 fuel tank specs
Hey Guys does anyone here have the dimensions of the stock 230 main tank? going to have am aluminum one built and im out of state form where the boat is located
Re: stock 230 fuel tank specs
Bueller?
If no one gets it before Saturday, I'll measure mine.
I replaced the 160+ gallon tank in my 1969 B31 FBC with a 230 gallon or so aluminum tank when the ethanol problem hit. I recommend that you pull your tank, and be real careful in measuring for your new tank. You need to get the angles right, as well as height, width, and length, and not every B31 is identical. Being a 1/2" off could be a real problem.
Users browsing this forum: No registered users and 103 guests
