running light placement
For those of you who have replaced the red/green bow lights, where exactly have you mounted them? As far outboard as possible or on the vertical portion of the bridge? If any of you are in New Jersey maybe I could take a look before drilling any holes.
Jeff
Jeff
Jeff - most of us have put them on the sides of the fb just aft of where the front starts to curve. I probably have some pix of mine and if you send me an email at royvictor@cox.net I can shoot them to you.
Thank You
Thanks for the responses. I think I have a pretty good idea now.
Vic- thanks for the offer but I don't think its necessary to send pics.
Tony- Still have the original, but its pooped out after 33 years of service.
I have a feeling that it may not be an easy fix, as this was the only wire on the boat not replaced when we repowered 5 years ago and I don't think the access improved since then. I thought while it was broken it may be a better idea to have the lights a bit higher, and the access to service would be so much easier. I never thought about the glare issue.
Thanks again for the responses and e mails. Now just waiting to splash to try out the new oversized rudders we installed this winter.
Jeff
Jeff
Users browsing this forum: No registered users and 53 guests
