For those with Dock Power & Lifts
Guys
Summer is hear, just an FYI to be careful in case you have not heard of two Tragic accidents this weekend. One was hear in NJ. A bunch of kids were swimming in the River and one touched the boat lift behind the house and was electrocuted. The lift was energized and when she touched it, it electrocuted her.
The other incident very similar took place in Ohio.
So if you have not checked your dockside wiring or your boats 110, please do so and be safe.
Re: For those with Dock Power & Lifts
I didnt know 110 v could kill.
We have 220 v and yes, this is a killer voltage, but 110 i thought would be just numbing and sour in the mouth.
Most boat lifts are wired 230vac. being that they are mounted on pilings, the metal lift support bars thru the cables can become charged if a motor leaks or the wires become chaffed and the ground becomes disconnected. Otherwise the breaker would trip.
When the tide comes up the water around can become charged or if someone swimming grabs a cross bar for support, they become a path to ground.
its not the voltage that kills you its the amperage
I saw this on the news also tragic accident
1968 hull # 316 - 757
I should have said 110 and 220, but a lot of us don't have boat lifts and 220 at the dock, but we do have 110. 110 can kill, as Charlie says it is the amperage. Even 110 needs to be carefully checked. We take for granted all is fine until it happens.
Have a weak heart, even low amperage could kill you.
Have you ever been shocked by a spark plug wire? I have a number of times when I was younger. If I had a weak heart, I bet that could kill you.
- MarkS
Nothing fills your shorts quicker than a spark plug wire shock! Well maybe except the time the old man caught me playing with matches, that was a pants filler too!
Pretty sad good info Tony.
MarkS wrote:Nothing fills your shorts quicker than a spark plug wire shock!
Never got a shock from plug wire or tweaking distributor till I was having motor done on Vette.
Engine had just gone in and Russ was tweaking the timing...he loosens the distributor a bit and says he hates these HEI caps he always gets shocked...I looked at him funny, I used to tweak the timing with every tune up, never an issue. Sure enough he lets off an MotherF-er as he touches cap. After that time...I got my fair share of shocks from cap.
My favorite was welding up Home Brew Pots for customer. Plastic sight glass needed a SS tab welded to pot side towards the top, to hold in place. Fixtures were awkward so I opted to hold in place by hand...A Real fine weld was needed, so had to get in close...if arc struck tab before pot it was one hell of a shock to which I jumped sending the glass tube of sight glass across the shop.
I was hit with 2400 v, back yard pole with transformer
putting primary tap on pot, bang arms went down and a warm feeling in my knee
were it came out, made it down, checked my rubber gloves and after about 20 minutes
found a pin hole but not all the way thru thank god, it picked up more of my sweat with the salt inside the gloves
I believe that would have been my last day doing that. In reality...there would not have been a first day. I hate heights and electric scares the poop out of me.Charlie J wrote:I was hit with 2400 v, back yard pole with transformer
Back in the day of timing lights, sometimes the guy that worked for my father would cross the wires on the battery connection which would give you that spark plug jolt when you grabbed the gun. The dumb guy tells my father everything is ready to go. My father realized the wires were crossed and he told the guy you time the car.
Last time the guy ever crossed the wires.
Users browsing this forum: Google [Bot] and 493 guests
