Hynautic Steering Help
tds8268
Post by tds8268 »
I have just installed new seals in my Hynautic Steering helm unit and was wondering if anyone can post the bleeding/refilling instructions for a single station boat. My helm unit is a three line h50.
Thanks much!
Dan
www.finchasersportfishing.com
Dave Kosh R.I.P.
Post by Dave Kosh R.I.P. »
Dan,
Try Charmens website. That's where I got my information and it worked swell. Look under bleeding instructions etc.
http://charment.com/ Dave K
Keep Fishing...
tds8268
Post by tds8268 »
Dave,
Never been the brightest but I can't find it on their site, even searched under bleeding. Any thoughts?
Dan
Skipper Dick
Post by Skipper Dick »
Dan,
Here is where I got mine.
http://www.seatechmarineproducts.com/do ... ctions.pdf
Dick
Kingfish
Bleeding the system
Post by Kingfish »
1. release pressure on tank.
2. Open fill cap and fill to last bubble.
3. Install cap and pump to 35 psi.
4. On the square valve you will see two round cylinders sticking out with nuts on the end.
Back these nuts off. They will not come off, they are attached to the check valves. Once loose, they will turn by hand.
5. Go to the cylinder at rudders and break on line loose to bleed air. When solid fluid, do other side.
Do not let the reserve run out of fluid or pressure, keep checking.
6. When the reserve gets below the last bubble, drain pressure, refill and pressurize.
7. Go to helm and turn 20 times slowly in one direction again checking fluid level and pressure.
8. Then turn 20 times in the opposite direction.
With the check valves open you will have no solid stops.
9. Check fluid and pressure and repeat last two steps.
10. Close nuts and try system making sure it has no air.
If it does repeat steps 7 and 8.
11. Final fluid should be at middle of last bubble and at 35 psi.
Use steering fluid, not atf.
Hope this helps.
Jim
1975 28 FBC
Users browsing this forum: No registered users and 188 guests
