Scupper Rubber
Chanse
Scupper Rubber
Post by Chanse »
I need to replace the material in my transom scuppers. Tried snow mobile flap material, too stiff. I'm sure they are perko's.
What kind of material do you guys use for those scuppers and where do you get it? Thanks.
Re: Scupper Rubber
I tried using a harder rubber and found they just let water pour in, slowed water going out.
Soft and allowed material to overlap opening a good bit (3/4" about)...allows water out and waves slapping into the back of the boat, the rubber sealed tight to hull.
https://www.mcmaster.com/#standard-rubb ... s/=17oiqb6
Re: Scupper Rubber
Post by Dug »
Carl beat me to it! I was going to recommend either McMaster, or Grainger, or perhaps MSC.
Or if you have a local industrial supply house, they might be able to help. Otherwise all of the above would be good sources with my first choice probably being McMaster.
Chanse
Re: Scupper Rubber
Post by Chanse »
Thanks for the replies, Mindboggling choices on McMaster!
Which of the many options did you think worked the best for scuppers?
Re: Scupper Rubber
Neoprene Rubber, multipurpose works fine. Outdoor rated.
I bought a couple different pieces to try...Can't recall which I went with, but was either 1/16 or 1/32 and pretty sure it was soft...med hard at the most.
I just recall thinking it was too thin and soft to work...but the rubber kinda got sucked into scupper a bit sealing when waves hit transom or rocking.
FYI- I still get water coming in...but not half the amount I used to get.
Chum Bucket
Re: Scupper Rubber
Post by Chum Bucket »
I would check your local plumbing store for gasket rubber used in various plumbing projects. Not the big chain stores, but Ma and Pa types. Should be able to find a 12" roll 1/16' thick in black, white, or thicker red. Buy it be the foot, it's cheaper than shipping from McMaster and allows you try a couple different thicknesses. If you can find a UV stabilized EPDM rubber, like what they use on rooftops, that would prob work better over time. I think I have the same type of scuppers on my B33. A craft type hole punch works wonders! I get about 2 years out of a set. Easy to swap out at the dock. Just my 2 cents.
Thanks, Kevin
Re: Scupper Rubber
Post by Yannis »
Have you tried a piece from a tyre air chamber, or is it too thin?
Navatech
Re: Scupper Rubber
Post by Navatech »
Yannis wrote:Have you tried a piece from a tyre air chamber, or is it too thin?
Definitely too flimsy... The same material in triple or quadruple thickness might work though...
IRGuy
Re: Scupper Rubber
Post by IRGuy »
I gave up trying to find something to use for the original scuppers, and bought a set of these from West. All plastic with a hinge and trap door..
West link..................... https://www.westmarine.com/buy/t-h-mari ... cordNum=13
They seem to do the job and I have no concerns about them drying out and getting brittle or deteriorating in any way.
ranjr13
Re: Scupper Rubber
Post by ranjr13 »
2nd Frank's recommendation - we have a set. Blow them out with a garden hose every so often so they swing easily, and be done with it.
Bob Norton Jr.
"Dalmatian - Essex, CT"
Re: Scupper Rubber
x 3. I love them and trash doesn't stick in them like it does when it gets halfway out of the rubber ones.
Navatech
Re: Scupper Rubber
Post by Navatech »
X 4... I replaced mine as well with these...
Users browsing this forum: Google [Bot] and 23 guests
