Ahoy Bob Lico
- JohnV8r
Ahoy Bob Lico
I just came across this post of yours regarding muffler relocation of the 6" Vernatone mufflers to make room for your fish boxes.
http://www.bertram31.com/bb/bbs.cgi?noframes;read=75141
Do you still have any pictures of this? I'm trying to visualize how far forward you went with the mufflers.
JohnV8r
JohnV8r
Re: Ahoy Bob Lico
john i place the 6" muffler just behind the rear bulkhead between the hull side and the first stringer. i cut a piece of 6" exhaust exactly in half (10') and used one piece for port and i piece for starboard this places muffler in the deepest place in hull the deck clears by 1/2" and no need for surge tubes trust me i tested in 6' sea as fast as i could go in reverse!!!!!!!! captain patrick loved this and jump on my boat to see this first time we met.6"----impossible "well seeing is believing" he never forgot from that time on.-------------sure miss him.
- JohnV8r
Re: Ahoy Bob Lico
Perfect! That's what I needed to know.
I miss Patrick too...
Thanks Bob!
Thanks Bob!
Re: Ahoy Bob Lico
john let me clearify one step; 6" exhaust hose comes in 20' lengths so i cut exactly in half and put transon end into 6" bronze thru hole adapter and the front end directly into muffler 6" output . look at muffler input you will see the large convex fiberglass shield this piece stops the water surge.the photo was taken prior to cutting exhaust plus clearance 6" hole in bulkhead!
Re: Ahoy Bob Lico
If you are still tight for space, JP used a smaller diameter muffler. I think it was made by veratone.
Re: Ahoy Bob Lico
tony that one does not have anti surge ability and smaller ID.
Re: Ahoy Bob Lico
john this is a finish view of exhaust . i had to take up part of cockpit to run controls for trolling valves .this is forever pirelli silicone 6" exhaust hose with 70 degree 6" fitting on the horizontal instead of 90 degrees for less contrictive exhaust flow before the short piece going to muffler.
Re: Ahoy Bob Lico
As Tony stated I used a smaller diameter exhaust profile, actually bob higgins 6",nel jr 5" and I 6" used the same type.
It's a 6" centububular centube. It's 6" continuos and will have a louder note at idle but be very quiet running and trolling. It allows for install further outboard as it is narrower then the veratones 8" bubble.
Chimera had surge tubes as do the other installs and therefore was protected, unless your using an in line check valve like primex makes or a rubber flapper on the exhaust flange I would recommend surge tubes.
Re: Ahoy Bob Lico
We installed the five inch and could not imagine anything else ,they are out of the way and quiet only problem is Jr wants them too sound loud kin,da like the Brewster boat nothing like the sound of no mufflers ,to be young again dad says keep itquite. But you all know they sound mean without exhaust kinda like the Brewster mobile
Re: Ahoy Bob Lico
Neil
Years ago, before the Bert, my father had an old Zoebels Sea Skiff. Straight pipes. Coolest sound ever.
Users browsing this forum: Bing [Bot] and 215 guests
