Ahoy Ernest
Ahoy Ernest
Counselor,
Here are the locations of the alarm switches you requested.
OIL
GEAR
WATER
Eddy G
Post by Eddy G »
Bruce: My B28 alarm system is the complete the circuit type instead of the ground out type. Luckily, Yanmar makes the two pole switches for the oil pressure and water temp. I have a gear oil temp position on my alarm panel, but no switch at this time. Is there a two pole switch available for the 63a? Thanks,
Eddy G.
dougl33
Post by dougl33 »
Bruce,
How did you get the spray paint lines so fine? And no overspray!
Regards,
Doug L.
Doug,
He cheats... Sprays 'em on a sheet of glass & holds the glass in fromt of the shot.
Eddy,
The gear temp is a two pole unit already.
Doug,
Thats the special boat show paint job.
Hyena Love
Thanks Bruce
Post by Hyena Love »
Thanks for all your help. Especially, your willingness to get involved in this project.
Eddy G
Post by Eddy G »
Thanks Bruce. Is that something I can get direct from ZF? If not, where?
Eddy G.
Yes.
Eddy G
Post by Eddy G »
Bruce: About the gear oil temp switch, I talked with the guys at ZF in New Orleans and they said I needed to get with Star Power, where I bought my engines for that part. Star Power said they don't sell the part, but it was a VDO switch that was ordered based on max gear temp allowed, port size and thread. I called ZF back to get the temp specs and port size and they'll have to call me back with that info. Do you happen to have the temp that the switch needs to be and the size / thread of the port? These guys over here are making me nervous. Thank you a lot.
Eddy G.
PS If I run into a dead end here, can I buy two from you?
Eddy,
You got more bullsh*t goin on there than a session of congress.
PM me your address and I'll get two going to ya.
Eddy G
Post by Eddy G »
Bruce, I sent you a PM. Let me know if you don't receive it. It seems to be hung up in the Outbox. Again, thank you very much.
Eddy G.
Users browsing this forum: Google [Bot] and 75 guests
