Calling Bob H. Can you talk about your exhaust configurati
John Nardi
Post by John Nardi »
Hey Bob...Notices the exhaust layout you had in your photos...Can you talk about what power you have and if you used mufflers or surge tubes and what material some of that piping is...Thanks
Re: Calling Bob H. Can you talk about your exhaust configur
John, I used 6" fiberglass exhaust with centubular muffler, along with custom made surge tubes. The engines are Cummins 6bta 370s, sounds very sweet, I would skip the muffler if I did it again. I also pitched it gradually so virtually no water is in the pipes with the exception of the very end. The engine exhaust came from Tony Athens and he has very detailed measurements to get your shower head water inlet about 18" above the waterline to keep #6 from sucking any water back in. Hope this helps.BH
Users browsing this forum: Google [Bot] and 7 guests
