Line drawing
Line drawing
http://www.bertram28.com/images/Bertram ... awingL.jpg
Can someone clarify the numbers on this line drawing?
Most importantly the height of boat from windscreen to keel/prop
Just bought a B28
Doing transport homework
Will measure my boat to be absolutely sure
Just bought a B28
Re: Line drawing
I shipped my 28 from NY to FL last year, but I didn't keep the measurements I made at that time. To the best of my recollection from the keel to the top of the wind screen is 144 inches. I removed the windscreen and placed it on the flybridge deck, and removed the props.
Re: Line drawing
I assume the print is too small to read. When I wanted my 31 numbers, I blew the line print up on a copier.
Re: Line drawing
Thanks Tony and Toeeze..Thats the problem
I can't read the numbers and zoom makes it worse
T
T
Re: Line drawing
Tooez..did you remove steering wheel and stainless rail around helm seats to can a few inches?
T
T
Re: Line drawing
Tom, I just took off the windscreen--not because of clearance, but because I was afraid that the airflow at highway speeds would rip it off. If you want any more info on how I prepped the boat send me a pm.
Re: Line drawing
Tom,
The dimension from Ground Line to Spray Shield Top is 11' 9-3/4". I have the factory book for an early 28 if you need more information.
Harry
Harry
Users browsing this forum: No registered users and 47 guests
