AJ interior remodel
In Memory of Vicroy
AJ interior remodel
Post by In Memory of Vicroy »
As part of AJ's transformation from a hard core fishing boat to a more mild mannered Howdy Boat (yeah, she will still chase blue suits, but not as hard) I'm planning to remove the dinette, lower the floor and put in a straight sofa. How big a deal is it to lower the floor where the dinette is?
Patrick, sorta like you did on Buddy Boy.
John F.
Post by John F. »
UV-
Its pretty easy to get a level floor to within 20" of the port side (to the plywood/pegboard piece with the 3 cutouts that runs fore and aft--not the actual hull side). Assuming that you'll want a 20" wide bench running fore and aft, it should fit real well without much trouble.
John F.
Terry Frank
Post by Terry Frank »
UV,
I've got a bench seat with storage under and behind it. Works out well. In no way is it a sof though. It's wide enough to lay on and nap, instead of going to the v berth which on a Sportfish model can be on step removed from a sauna. Best of luck with the project.
Terry
Terry Frank
UV,
While your womanizing AJ maybe Timmy can send you plumbing plans for a bidet. I understand they're standard equipment on Hats.
Yo' fren,
Terry
In Memory of Vicroy
Thanks, guys. Does not look that hard, and yeah, about 20" wide ought to do it. In fact, the cushions I have on the dinette now will fit on the bench. Plumbing? I got plumbing already. Thinking about adding a shower and bidet tho.
I thought the washdown pump doubled as a bidet!!!
Capt. Mike Holmes
Washdown
Post by Capt. Mike Holmes »
Rawleigh, you are obviously remembering the trips on Lil' Bert out of Port Eads!
That must be it Mike!!
Hal
Post by Hal »
Wow, UV. Those are big plans for a daytripping howdy boat.
But where are you going to put the bar and kegerator?
Users browsing this forum: Google [Bot] and 58 guests
