Boost Question
Boost Question
Put boost gauges in for lp6 yannies and the question is, do I need to put copper tube comming out of the fitting tapped in on the engine or can I put the plastic tube strait to the fitting without it melting?
- Capt. Mike Holmes
boost
I've used both, only problem with the plastic is it can get pinched, but so can copper. I've also run the lines from the turbo to the gauges, now from the intake fitting, didn't see much difference.
Users browsing this forum: Google [Bot], Whaler1777 and 78 guests
