Fuel Pickup Bronze Plate Replacement
- Vince Luciani
Does anyone know where I can get a replacement for this fuel pickup plate. This is what I found when I took my deck up. I guess I could fabricate one if necessary, but I was hoping to avoid that if possible.
Vince
Vince
- Vince Luciani
Vince,
I doubt seriously that the bronze manifold plate is corroded, other than surface oxidation. I can see that the steel sender plate is shot...
Once you get the manifold plate off, stripped down of valves and such, it'll clean right up. You can use muriatic acid to clean the surface. Paint it on, let it sit, rinse it off. Do as many times as necessary. Finished acid clean up will leave it copper pink as the surface tin will be etched away. Left this way, it'll eventually turn green & stop further oxidation.
A small stainless steel wire brush will also help through out the process.
If, and I doubt it, there actually is a pit that goes all the way through in the bronze plate, it can be brazed, silver soldered, or even lead soldered....
That plate assembly is, by the way, totally unavailable as a new item, but is probably the one item on the boat that will out last every other part.
- Vince Luciani
Capt Pat,
I might have the first one that doesn't outlast every other part. I definately have holes in mine. I found them when I power washed everything at demo time. I can put a screwdriver thru them. The first picture probably shows them best. It is the dark area. The plate unfortunately fell right on the edge of one of my hatches. It was subjected to alot of leakage from the deck. The return plate is in excellent condition.
I'm sorry to hear that the plate assembly is not available. Does anybody who's getting new tanks want to sell me one of their old ones?
Vince: The "dark area" in your photos is the sending unit mounting plate, held to the "fuel pick-up plate" by 5 screws. If it was the old swing arm with a float type, it is trash anyway. You need a capacitance type fuel level sender anyway, no moving parts. Made by Centriod products, Edgewater, Fl. 386-423-3574 they will need info re; tank size and configuration, but only sell to dealers, but will give you name of dealer you can buy from. These units are the only way to go, mines been in service 14 years, old swing arm mech style would corrode away in less than a year!! Plus centroid now has a computerized fuel gauge that computes fuel burn/hr. Their sender is compatible with older style gauges.
Ted
Ted
""Procrastinate now!"
Vince: Take it off and drop it in a bucket of 50/50 muriatic acid and let it cook for a while. Or if you like the bronze color, take it to the local auto shop and have it bead blasted. It will probably be perfect. If not, get back with me and I may be able to fix you up. Worst case, any good machine shop can duplicate it for not too much money.
Vince,
Like everyone else, that hole you see is the fuel guage sender, that is a seperate unit from the main plate. There is a 1 1/2" hole in the fuel plate that the float from the sender goes down into. If you remove that old sender, you'll see the nice round hole.
Remove the screws around, disconnect or cut the wire and pull the unit out.
Chase the holes and install a new sender that matches the guage resistance you have and depth of tank. You can go by the brand of guage.
- Vince Luciani
Vince,
I'm stickin' to my guns... In the photo part of the above image, am I pointing, (white arrows), at your hole(s)? If so, then the holes are being poked through the rusted out steel sender flange. There is a fair sized hole directly below those points that the swing arm sender mechanisim goes down through, as diagramed to right...
- Vince Luciani
hey guys have you ever had a problem with the pickup tube cracking? Mine had a crack running lengthwise so that when i was up on plane i had fuel but when i slowed down like to start fishing the engines would die like i ran outa gas. Since it started sucking air anyways i picked up a new brass tube and silver soldered it in the distribution block. Just thought i'd give you all a heads up, that it can happen if it hasn't already to you guys.
- Capt. Mike Holmes
Pickup tube
Better to have a separate pickup tube for each engine, in my opinion, and there are lots of parts replaced with other than original in these boats over the years. It would be a shame if we stopped listening to each other and sharing ideas, just argued instead.
- Capt Dick Dean
soldered pick-up
When I posted last week about my clogged fuel pick-up screen, I noticed the solder balls along the sides of the p/u tube. Now I know that that's the way it was originally constructed and not a batch job by a former steward!
Doc
I had the same copper screen soldered on mine. just that the tube was brass and a solid piece. It looked original but i could be wrong. I also had the cracks kinda wrapping around the tube and not going perfectly vertical. I just wanted to keep this fresh since i know how aggravating it could be if this happened to a newbie who didn't know about this problem. Since a cracked pickup tube is one of the last things i would be checking for if i had the problem. Also i made a ring out of aluminum and put heli-coils in it to make a nutplate if you will, so i don't have to fool with nuts or anything going inside the tank it really did a nice job.
actually i didn't fasten it to the tank. one because i didn't know if i'd like it and two because the bolts themselves hold it up i just held it in place by hand, sticking my arm through the oval hole and starting my bolts. Its a lot easier worrying about holding a ring then some little nuts. I know i took pics i'll try to dig em up if i can.
Users browsing this forum: No registered users and 357 guests
