Max Wax testing results
Has anyone reported the results of the anti-fouling properties of Max Wax? If so, do we have a verdict?
I used the stuff on my tower.. & was pleased.
One thing I found. If you dont use the whole can,or even take time between squirts,the next time u go to use it the nozzle is plugged.. Even if you upside down spray it finishing up.Even tried to use another nozzle. No go.
Im afraid to use the next can on something..
Wayne
Wayne
Wayne,
I assume you have a can or two of red label CX...
After using the Max Wax, put the nozzel onto your can of red label & shoot it clean. Then use the red label & the little plastic straw to clean out the Max Wax can opening. You'll be good to go the next time you reach for the Max Wax.
