my 1961 Bertram 31 history
Hi, I purchased a 1961 31'Bertram flybridge in Fort Lauderdale last year and I'm trying to find out previous owners and get some history on this boat. I purchased it from Jose Portela ID #31106. He is an older gentleman who acquired it in 2008. I don't know who he purchased it from but I believe he bought it in Fl.
On the flybridge a small plaque with Pinky 111 WXD 2669 was the calling number. I'm just wondering if any one has any info on the boat. The serial # is on the title but can't locate it on the boat or hull #. Where do I find this on a 1961.I'm restoring the boat and looking forward to finding more info. thank you Al
Re: my 1961 Bertram 31 history
It's possible that you have hull #6 of about 1860.....
The hull numbers became part of the hull, molded in on the transom in 1972. You will probably find numbers written on different parts in the boat that matches the hull # you have.
Look on the transom, in the bilge area. They some times printed them on that part of the Hull. Others found them under the V berth.
If you have #6 like Mike said, it might be the earliest version we all know of. I don't believe we have come across Hull #1 as of yet.
Maybe Capt. Pat will know if any of the members have come across #1.
- MikeD@Lightningshack
My 1969 had the Bertram hull# printed on a paper placard that read Bertram Yachat & Whittaker Corp. I would bet your Bertram hull ID number is on the transom, inboard stern about 3 to 6" above the keel or the bottom of the "V". Right behind the aft bilge pump. It is a placard that is basically a piece paper maybe 4x6" that was laminated into the fiberglass. You won't see it unless you carefully remove the paint and clean the surface. I found mine only when I had the tank out for replacement.
Tracing the history can be very easy if the vessel was documented at any point. The Coast Guard makes all of this information readily available. If it was documented you can even call the Coast Guard directly and request a "Master Carpenters" certificate. This document was required to document boats before HIN were started. The Master Carpenters certificate will have the hull number also. The Coast Guard was extremely helpful in uncovering the history of my boat. They were responsive and informative, unlike any other government agency I ever dealt with. My former boat had a handful of different owners but was originally called the "Lobster House" and was owned by a fish company in Cape May, NJ.
Last edited by MikeD@Lightningshack on Oct 17th, '15, 13:06, edited 2 times in total.
- Bertramp
There was a thread a few yrs back regarding hull numbers and including them in your signature.
Lots of info.
We came to conclusion that approx 100 were made each year....
Lots of info.
Steve "Bertramp" Kelly
I agree with Mike: it would be the 6th B-31 built. Longtime Bertram engineer Lee Dana confirmed in an email to me that the first fiberglass hull popped out of the mold was hull # 31-101, so Al's would be #6. The original wooden Moppie that Dick Bertram raced and won in the 1960 Miami-Nassau race was used as the plug to build the split mold from which all the 1860 or so B-31 hulls were layed up. Nice find, Al; how about posting some photos for us.
Al,
The hull number for the early 31's were on a piece of paper glassed into the hull up under the Port V berth. Lift up the plywood under the cushion and look just under where the plywood meets the hull side. Piece of paper with Bertram Yacht a Division of Nauta Industries Miami, Fl. on it, should have the hull number in black magic marker 31-106 and a date, that is the date of the keel lay up. I sold my 1961 express last year she had the paper tag 31-186 12-13-61 printed on it, hull 85 the last boat they layed up in 1961. Your boat is hull number 5, they started with hull 101 so yours is hull #5. Mine is now living in the American Virgin Islands and was repowered with small diesels after being a gas boat all it's life. I had it for 37 years. Other places to look are on the back of the head ceiling panel, on the bottom of the galley drawer or under the cabin sole floor boards. Welcome to the sand box enjoy the boat.
Thanks for all the info, I will continue my search. I forgot to mention that my flybridge was not molded on it was attached with
@ 30 bronze bolts. I will read instruction how to send pictures and forward a before and present . thanks again
I believe that's par for the course... I.e. AFAIK none of the flybridges are actually molded as part of the cabin roof... The flybridge is a separate mold... That's certainly the case for my 46' and every 31 FB that I have seen...alscars55 wrote:I forgot to mention that my flybridge was not molded on it was attached with @ 30 bronze bolts.
Looks great! Keep the pictures coming. Love the progress.
Looks great.
If you're going with gas power, you'll need to replace the fuel tank. The old tank will be fine for diesel, though you might want to clean it out a bit.
Oversized rudders are one of the best modifications that you can make.
And get rid of those trim tabs. The 31 doesn't need them.
Great pics..keep up the good looking restoration
You are doing spectacular work!!!! Beautiful!!!!
Very nice. I like your bow rail. Still looks classic, yet sturdy and streamline. Nice job on the windows too. Keep the pictures coming.
Steve Marinak
Duchess - 1973 Sportfisherman
Great ! Why didn't you pull the antifouling up to the chine all the way fwd ?
Enjoy your boat !
Enjoy your boat !
Painting the bottom up to the chine all the way is the argument of the century. It is really a matter of choice.
Re: my 1961 Bertram 31 history last picture
Wow- that looks fabulous.
Did you rebuild the front window frames or fabricate your own or something else??
Best,
Stephan
Hi Stephan, I built a mold on the boat,removed the mold and brought in in my shop and made a complete new frame all out of fiberglas. I also made the side window frames new all out of fiberglas.
It came out fabulous. I still have the mold if anyone is interested in purchasing .
Here are a couple of pictures.
Wow... what won't people do for these boats!
Impressive work!
One thing I learned on my winshield install.... the tie rods that hold the top down to the window are important structural members.
Intuition makes you think that the window are needed to hold the bridge up. Occasionally when the boats bounce around the top of the bridge feels upward forces. So the windows hold the top down also. Lots of glass at Top an Bottom window seam is the onlyway to carry the loads. Or if you leave the tie rod in you can use less glass.
I used a Holmsey insert. I thought my project was laborious. Childs play compared to what you did.
Thanks for sharing.
Impressive work!
Thanks for sharing.
Boat looks great. Your f'glass windshield frames are pretty incredible. Nice job.
Over the top man!
Keep it up..
Keep it up..
That is quite a mold.
Boat looks great, keep up the great work. It will be well worth it.
Hi, I'm John from FRANCE
I buy a 1961 B31 too
For your perfect information, it's the hull number 173 from the 11 july 1961...
If you still have the mold, I'm very interested by.
Please contact me directly by mail :
jean.morel@polytek.fr
Thanks and regards
John (Jean en Français)
+33 6 07 25 85 33
Thanks and regards
+33 6 07 25 85 33
alscars55 wrote:Re: my 1961 Bertram 31 history
by alscars55 » Oct 21st, '15, 08:45
I have not seen Alscars55 post in quite a while. If you click on his name, you should be able to send him a PM. That would be your best bet on this one, if you want to track down his mold.
Just read through this thread fast-----I didn't see anyone refer to the two part bridge------
I have only seen one other boat like this----it was an early boat as well---blue hull with a tuna tower call the "Stroker" last time I saw it it was docked in Point Lookout, NY-------
Alscars55,
The bolted on fly bridge makes sense because the original hull configuration was a sedan model (311), no Fly bridge . Someone either got ahold of the mold for the fly bridge or maybe it was added before the molds were destroyed in the Carl Herndon era at Bertram in the late 80's.
I looked at that boat back in the early 2001 or 2002 It was owned by an old timer and was berthed behind a condo complex near Hillsboro Blvd off Route 1.
Your doing a great job on the refit.
I once owned hull number 4. I purchased it on Long Island and kept it in Babylon, Asharoken and in Montauk. I sold the boat around 1980 to several NYC firefighters.
I once owned hull number 4. This is the Stroker, a blue hulled 31 with full tower. At the time it had twin 440 Chryslers in it. I purchased it on Long Island and kept it in Babylon, Asharoken and in Montauk. I sold the boat around 1980 to several NYC firefighters. Today, I own another 31 by the name of Honey Bee that I renovated. I keep it behind my house in East Hampton, NY.
Hull #4 is probably the oldest we have come across any members owning. Did it come from the factory Blue or was it painted? I remember reading that Bertram made Hull #1 Orange. Never found out if that was true or not.
Jaded Lady was a very early boat too, I think.
Users browsing this forum: Bing [Bot] and 78 guests
