Strainers?
Joe E
Strainers?
Post by Joe E »
What is my best choice? Trap door? Regular slide out screen? Or positive flow slide out screen. Thanks Joe
http://www.downwindmarine.com/Hull-Stra ... 91170.html
http://catalog.buckalgonquin.com/item/p ... 00rss110pf
http://catalog.buckalgonquin.com/item/r ... 00rss110sp
Re: Strainers?
Joe,
Hands down, the Groco APHS Hinged Door is what you want. Get the next size up for whatever your through hull fitting is and you should be using a full flow fitting, not the standard. See: http://bertram31.com/proj/tips/strainers.htm
Joe E
Re: Strainers?
Post by Joe E »
Thanks cap. My through hole fittings are 2 inch and I went with full flow fittings.
I forgot to ask what size holes I should go with.
Thanks again Joe
Re: Strainers?
Joe,
For 2" full flow fittings go with the 3" APHS-3000. The Perforated Screen - 0.077" Diameter holes is standard and no options for smaller or larger holes...
Joe E
Re: Strainers?
Post by Joe E »
Thanks just ordered them Joe
Users browsing this forum: Google [Bot] and 6 guests
