Fuel issue ? Cummings 4BTA3.9M250
Been sitting for months
Primed it and seems to hold prim but cracking injectors on the running motor or the not running motor no fuel comes out.
Filters and lines are full.
Starting fluid third try kicked a little.
Fuel pump ?
Pressure gage where to connect ?
Fuel return line any help crack it under starting ?
Checked all the power seems good.
Thanks Guys
https://youtu.be/Nod551nieZ8
Fuel pump ?
Thanks Guys
Re: Fuel issue ? Cummings 4BTA3.9M250
How did you prime the engine?!... What type of transfer pump do you have?!... Diaphragm or piston type?!... Have you checked your oil?!... Does it smell of diesel and is it "thinner" then it should be?!...
PM me your email address and I'll email you section 5 (fuel system) of the trouble shooting & repair manual...
Frankly it shouldn't have to be primed unless the system opened.
Always welcome...Keith Poe wrote:Thank you for the help.
Sounds like you may have the Bosch injection pump... That one has a small priming pump on it...Keith Poe wrote:It gas a pump on it for priming.
Manual on the way... 3 emails due to size... They're from boat diesel.com... Consider a membership there...Keith Poe wrote:Sharktagger777@Gmail.com
That is, of course, a correct observation...Rawleigh wrote:Frankly it shouldn't have to be primed unless the system opened.
Keith
Make sure the pick up tube is good. It might be clogged at the bottom.
Keith...
Do your 4BTs have integral air preheaters.. as my 6BT does? If so.. Do not use ether starting fluids!
I don't know if they do or not but it's above 60 degrees here and I leave the key on for several minutes before spriaying
I believe I know what the problem is hard to post with this phone I'll reply tomorrow
12' MAKO Hand Line: https://youtu.be/6-CM0jyNtTE
Please do... Might help...Keith Poe wrote:I believe I know what the problem is hard to post with this phone I'll reply tomorrow
Keith
I hope you have a lot of life insurance without a Shark exclusion
https://youtu.be/ZMErtUaWgpc
BIG MAKO 100# of Drag
When I put her away months ago she was running great.
I put the starting fluid to her and she seems like she wants to run black smoke out the exhaust.
Thanks again for any help guys
4500# Still tracking her from 32 months ago
Tagged her in a 19' Davidson Albie
Also ran 5 Basking sharks last season in the 30' Class
https://vimeo.com/71425807#share
Keith,
With all the high temps you have been having out there, I would make sure you don't have algae blocking the lines, eithet that or you have lost the prime in the fuel system also check to see if the fuel vent is clear, no hornets nests in the line.
Hey Petes I've been dipping the tank and I've inspected it I don't see any algae
The starboard motor fires right up runs like a top
Thanks for your help. What about the black smoke coming out the exhaust that would indicate the fuel is combusted but it seems it doesn't want to stay running possible electric
Now the part I haven't told anyone yet big ass mako destroy the air vent
Rag I had stuffed in there came out and I didn't know it salted the motor
Burnt up a wiring harness
I repaired it to make it in
Other than that ran fine I'm assuming the salt screwed something else up so far everything I check has power function
Sorry for all the post if I write more than a few lines on the phone it starts to scramble everything
I'm not sure electrics are your problem... IIRC these are old school non electronic diesels... You only need electrics to start the engine (i.e. turn the starter)... You MIGHT have one that has an electric lift pump... IF electrics are your problem and you have one of those that might be the place to look at...
Having said that, and assuming my recollection is correct, I would still redo the wiring... There shouldn't be that many wires... If my recollection is bad and this is an "electronic" diesel I'd definitely go for a new (or used but known to be good) harness...
The fact that you're getting the right voltage doesn't mean you're getting the right amps... A partially busted wire will still carry the right voltage but won't be able to supply the right amps...
Thank You
Got It Going after checking the injectors and everything lift pump etc. found it did not want to suck air lifted the valve covers and one was stuck after 164 days sitting.
Started instantly.
Thanks again for all the help guys.
Started instantly.
Going to trailer it down to the launch ramp tonight after the wide load curfew slap the spurs on and let her breath.
Users browsing this forum: Bing [Bot] and 112 guests
