Does anybody know the exact dimensions of the two beds in the side cabin of the B33 (version with two cabins) ?
Thank you.
B33 info
Re: B33 info
I have a 1988 FBC. I'll measure the two bunks today for you.
Re: B33 info
Buzzk, very kind of yours.
Re: B33 info
My boat is a 1988 Bertram 33 FBC. The top bunk bed is 77 1/2 " long. 38" wide on one end and 28" wide at the other. The bottom bunk is 77 1/2" long. 36" wide on one end and 24" wide at the other. My cushions are 4" to 5" inches thick. I measured from the top of the mattress and they are cut at a angle or tapered to fit the hull of the boat so the bottom side of the mattresses are more narrow than the top side. The top bunk measures 77 1/2" inches long and 36" inches wide on the bottom of the mattress on the wide end. The narrow end is 23 1/2" wide on bottom of the mattress.
The bottom bunk is 77 1/2 " long and 34" inches wide on the bottom of the mattress on the wide end. The narrow end is 22" wide measured on the bottom of the mattress. If this doesn't make sense let me know and I'll try again.
Re: B33 info
Buzzk,
Nobody on this planet, in other planets too, would expect a more thorough measurement.
Thank you for your effort.
