Aluminum Tank $$
- Davidr0007
Aluminum Tank $$
Has anyone priced an aluminum fuel tank for a 31
DavidR
DavidR
David,
I'm replacing my 190 gal rear glass tank in my 28 Bert with a 260 gal aluminum tank. New tank is made with 3/16 metal and will be coated. Was quoted $4,625. Thought that was robbery but started checking around. Seems that sheet aluminum has pretty much doubled over the past year. THat price is still a bit high, but not outrageously different from other ballpark quotes I got.
Ken
Ken
- Davidr0007
- Terry Frank
- Davidr0007
- Bulletproof
New tank cost
Hi David,
I spoke with Doug from Nautic in Fla and he prepared me for something between $2,000 and $2500 but wants wo hold off until I send him a print for my tank size. About 6 months ago he suggested $1800 but stainless has gone way up since then so he won't quote until I give him an order. He says he's very busy and won't take an order with a dead line. That's fine for me since I won't be going in until next summer.
Good Luck!
Paul
Good Luck!
Paul
Paul Haggett
B31 Bulletproof
Marblehead, MA
B31 Bulletproof
Marblehead, MA
Just a thought on the tank replacement. I have alot of fabrication done for my business by a guy who is very good. I asked him to build me a tank. He said no. I spend $250,000 or more with this guy each year, so I was surprised by the response. He did not want the liability of building the tank. So, I had him shear and form the componants, had a certified marine fuel tank builder assemble it. It cost me $350 for the material, $300 cash and 24 beer for the assembly. 110 gallon tank. My delivery was also moved up by 4 weeks because I was supplying the material already sheared and formed. Just a thought for those frustrated by the backlog and cost of tanks.
David
You may want to talk with Richard Kidd down Richard Bertram. I was talking with him and he plans on having a fiberglass tank, 100% ethanol proof ready in 6 to 8 weeks. He already has one for the 28 and the 31 is next. He said it is being built by the same company that builds them for Bertram Yacht. Tony Meola
- Davidr0007
Fellas...
Could some one please give me a quick rundown on this fiberglass tank problem. I have a 82 B33FBC with one 315gal gas tank. What exactly is happening ??? Is the f/g tanks leaking, or are they dissolving. What exactly is going on. Does this f/g melt, and get into the fuel...and cause engine damage ??? Is there anyway to filter it out....man you guys got me scared...these are some huge numbers !!!! Any help apperciated..thanks
Ken
Ken
Ken
'82 33FBC w/gas
Thornwood,NY & New Port Richey,Fl
'82 33FBC w/gas
Ken, yeah it's scary.
The fact is that ethanol will breakdown our fiberglass tanks due to the type of resin used to make them.
Once the tank starts to breakdown there's a residue which passes through filters that then solidifies in the cyl chamber causing sticky valves or imporper seating and the engine eats push rods and then itself.
Even if your tank doesn't breakdown (some have not), the ethanol fuel will leach water from the gas & atmosphere. So without good water/fuel seps the water'd down gas will cause problems. Also this will lead to the ethanol being separated from the fuel resulting in a 'low quality' fuel leading to valve and cyl-head problems. MFG will dodge the warranty repairs if your fortunate enough to have new motors, blaming "poor fuel quality".
I say it's like playing russian roulet but you only spin once then keep pulling the trigger until BANK your dead....
do a search on the old board there's lots of stuff there. There's been some good discussions on the topic.
In the end we each digest the data and discussions and make our own decisions.
br,
JohnD
"Lady D" a gas B35
br,
JohnD
"Lady D" a gas B35
It's problem, but siting in a boat yard every day observing, there is more reaction than action, meaning, people are swapping out tanks left and right, some minor fuel filter clogging, but nothing major to report at this time.
Clean your tank and we sell K-100 and I T WORKS!!!!!!!!!!!
K-100 is not cheap, but either is your boat.
We tested K-100 and Starion(spelling maybe off) both claim the same as to be able to mix the gas with the water to make one.
Took two glass jars filled with gas/water mix 80/20 shook, let settle, Starion had separtated, the k-100 was one and one color of gas. In addition, we took a oil pad put equal size pad in both jars, Starion nothing was absorbed, K-100 everything was absorbed, remember the oil pads don't pick up water!!!!!!!!!
See at the Bluffs
Keep Smilin
See at the Bluffs
Keep Smilin
Unique Name
As I professed, it is a problem, a definiate problem. When I was stating no major problems I should have clairified that we have not seen major problems here at Onset Bay Marina with our customer base or any of the many transients we get.
Massachusetts has only had ethanol since May 1st. so I am sure well see more problems in time.
Keep Smilin
Keep Smilin
