Deck support beams
Deck support beams
What type of wood was used for the deck beams as constructed by Bertram?
Re: Deck support beams
When a couple of mine showed signs of weakness, I sistered them all with 5/4" mahogany.
There's a reason mahogany is so popular in marine applications... IOW, you can't go wrong with mahogany...
Having said that, personally I would go with a prefabricated structural FRP U shaped profile...
Thanks to everyone. My son and I thought the same.
I used Coosa, never rot
I had my deck up to replace the fuel tank. Some of the floor supports were less than stellar. So I replaced all with structural channel from McMaster Carr. They worked wonderful. I bonded them to the stern and cut the channel to make vertical posts tha were bolted through the stringers and the floor beams. Strong and never will it rot.
1972 Bertram 31 Hull 1018 "Knot Again!" - new to me July 2014
Users browsing this forum: Google [Bot] and 315 guests
