My B31's water tank will not allow the pump to hold pressure, has anyone else had this issue?
WC
Water Tank Problem
- williamcash
Water Tank Problem
Nothing beats the B31, especially in the Bahamas!
Re: Water Tank Problem
It depends on how your water system is pressurized... Some systems have a pump that will kick in as soon as you open a faucet... Other systems have a small (think along the lines of a half height standard fire extinguisher) sized pressure tank... Basically the tank has a membrane in it... With water on one side and pressurized air on the other side...williamcash wrote:My B31's water tank will not allow the pump to hold pressure, has anyone else had this issue?
If you have the latter type it's possible that your membrane has gone south... Or, that the air side has lost pressure... You can try to pump up the pressure... Look for something that looks like a car tire inflator thingy... A bicycle pump will do...
- williamcash
Well the thing about it is that the pump will get pressure, and good at that, but it cannot hold it. I will get a video and pictures later.
WC
WC
My original water system was a pump that sucked water from the tank,and only if the tank were empty would/should u Lise pressure, I'd look for a leak on the pressure side going to the faucets etc,sponge dry the various bilge areas ,try the pump and see where the leak is located
WC,
The stock B31 tank is a vented tank, so cannot be pressurized. The pump draws water from the tank, probably on demand if you're using a modern demand pump. The little plastic pressure tank, if present, only somewhat buffers the frequency of the on/off cycling of the pump.
The pump will only apply pressure when a demand is presented, (faucet opens). Either you possibly have an air leak on the suction side or a water leak on the discharge side.
Check all of your fittings and hoses for leaks...
- williamcash
Well what I thought the problem was is that the hose coming to the pump from the tank is smaller than the output on the other side of the pump, when doing any work to a 31 did you seem to have a small hose coming from the bottom of the tank?
WC
WC
Did u change the pump size, the system has been there for many years and working properly, one way to possibly use the existing hose relationship is to pump the pressure side to an accumulator tank,they take up space,but may solve your problem
Users browsing this forum: Google [Bot] and 238 guests
