code reader
code reader
Guys i'm looking for a code reader to hook up to my marine power 350 efi's. Its the mercruiser gm style computer just wondering if anyone knows of a place to buy one. thanks
- Skipper Dick
Scooter28,
I use Techmate From Rinda Technologies on my twin Merc Horizons. They have the MEFI 3 ECM.
Their website is http://www.rinda.com/marine/marine.htm.
Dick
Dick
scooter28,
A couple of things.
If you have the service manual where you can translate those flashing led's into faults and then be able to diagnose those faults, most of the time multiple faults, into repairs your golden.
The scanner will allow you to do injector tests and will display the actual code number and description and data the computer sees including fuel burn.
Both will allow you to put the engine in service mode to set base ignition timing.
Now for part 2.
90% of all the gas repairs I do on these engines are still related to the basics; fuel, air, water, battery and corrosion. Something that the computer is useless for.
Had a Merc in the shop that wouldn't start. Showed a bad crank sensor, switched out with a known good one and no go. It turned out to be a harnass issue.
You could go thru a bunch of expenses replacing sensors when most of the time they are fine and the faults are generated by other things.
Most of these components are GM ignition parts that have been in use for 20 years and are very reliable.
Go slowly with your troubleshooting. Most sensors can be measured with a good quality vom meter to double check.
A couple of things.
Now for part 2.
Users browsing this forum: Bing [Bot], Google [Bot] and 184 guests
