DUAL TIE-BAR KIT for Mercruisers for B25?
New Mercury Mercruiser Quicksilver OEM Part # 96708A 4 DUAL TIE-BAR KIT
anyone have any suggestions on where this might be in stock. local dealer is $800 but not in stock. Ebay is $550 but say these are on national backorder. this is the last piece of the puzzle for a b25 repower.
Bill
BERG1474M74J-315
BERG1474M74J-315
Re: DUAL TIE-BAR KIT for Mercruisers for B25?
What engine configuration are you using? I have a tie bar that was used on my Mercruiser 165's that i'm not using. If this is what your looking for it yours.
-L
-L
- MarkS
Can I ask why you want one of these?
I am getting this info from someone the guy who is doing the repower so bear with me.
lpd3: what i have is the pump on the port side and the slave in the middle. if its not too much trouble, could you take a picture of what you have and let me show it to my guy?
marks: the previous owner only had a tie bar on the outside and the guy who is doing the re-power is a "by the book" kind of guy. he says he wont send it back out like that and i am glad.
thanks Bill
thanks Bill
Bill
BERG1474M74J-315
BERG1474M74J-315
96708A 4
Used with power steering cylinder mounted on the port transom plate. Adjusts from
29 in.(737 mm) to 37‑1/2 in.(952 mm)
Fits 1983 and newer R/MR/Alpha One/Gen II and Bravo models, except D7.3
Bill
BERG1474M74J-315
BERG1474M74J-315
Anything here that will fit? External tie rods like this is what we used on go fasts.
http://www.lathammarine.com/full-sternd ... lies.htm#1
Rawleigh, the way it was explained to me was. inside bar for normal or inside and outside bars for high performance but not outside only which was my setup.
Bill
BERG1474M74J-315
BERG1474M74J-315
- MarkS
I have mine slaved to both outdrives on the inside of the transom. The only advantage I could see is they will never kiss if you have a steering failure but regular maintenance and a regular inspection should be a yearly event at any rate.
Just my $.02
Just my $.02
Is it possible to have a machine shop make it up for you out of stainless. Prbably cheaper also.
Users browsing this forum: Bing [Bot] and 304 guests
