Gas Tank Dimension Question
I recently bought a 31 and although the inside of the tank is gelcoated, I am going to replace it. The deck is a glasstech deck put on 3 years ago so it should be fairly easy to remove. I am a few hours away from the boat but want to get some prices on a tank. Does anyone know the dimensions after the glass is cut out?
Mike,
The stainless steel tank that I had made for Gerry Santiago's B31 FBC is a bit longer than the diagram below, but all other diamensions are the same.
If your B31 is pre-1972, you will need to reduce the height of the tank or raise your deck height accordingly.
Click on the image for a larger image...
![Image](http://bertram31.com/santiago/images/boat/fuel/tank-sm.gif)
I have found your site so useful. I have been around boats since Iwas a kid and am 31 now. Tbe boat Isgair is in LBI, if you ever make your way up there, I would be honored to take you out for dinner and some beers
Thanks Again
Thanks Again
Users browsing this forum: Briancc, Google [Bot] and 72 guests
