Underwater Lights??? Suggestions
I want to get some underwater lights. Any suggestions on manufacturers, types (halogen, LED, Xenon, HID)
Anybody ever used EFX Lighting, they seem very reasonably priced and they have a surface mounted light. Only problem is the housing is 316 Stainless (instead of bronze) and I am little concerned on how it would hold up in Saltwater under water all season.
Suggestions? Best light for the price.
le3,
Agualights is the brand that a few of us here on this site have bought as a group a couple months back, metal halide(HID)/120v ltgs. being the best and most expensive, then comes Zenon/120v which would be next less expensive in line, then Halogen/12v which is what most of us here went with and could upgrade those to Zenon if we wanted too, by changing out the inner guts.
LED's are not bright enough in my opinion right now for underwater lights, later on they will get better. You can scroll back a few pages and find pictures posted of 31's with underwater ltgs. installed on the transom.
Hope that helps you.
DQ
DQ
Yo!!! DQ
You up and runnin yet with the lights. Still got mine in a box. Been up to my eyeballs in teak dust, fiberglass dust and boat parts. Engines/new trans get set this week along with covering boards and teak deck. 20 more coats on the rear bulkhead and we'll be good to go.
Anxious to hear how the 75h's look in the real world. More importantly did you find a brighter bulb?
From the pics I've seen here the boats looking good.
JP,
Ditto! trying to get the flybridge painted and get thru with the rest of the refit done, just slow going when your solo on a project. Weather's cold & crazy& breezy down here lately on the Gulf Coast but not like you guys are. I ready to shoot that freakin blind ground hog!, Shadow's Ass!
Your ride is looking down right awesome. I have your upgraded bulbs when your ready just shoot me a PM and address and there on there way.
Shoot me a PM with your phone# so we can talk.
le3- go to Aqualights website and see what there posting on prices today.
DQ
DQ
le3
In any boat. It's easier to use 2 people (one in the boat and 1 out for the install) then the helper can run wire and pretty up the loom while the connections are made at each end.
Best guess for 2 lights out the back would be 4 man hours plus travel. Thats a working best case scenario, meaning the electric panel has a space to drop the breaker in the panel itself is safely and correctly wired to the batteries and the bilges aren't loaded with oil residue and fish parts (the lights need a clean sealing surface for caulk). Average rate for a reputable private installer is around 70 per hour plus the cost of lights and any travel. If you use a marina it could be as much as 110.
If its something your thinking about shoot me a pm I can give you a few names of people you can trust in the central jersey area.
- Capt. Mike Holmes
Hurley lights
You might want to look at the Hurley lights. They mount two 75 watt Halogens on each trim tab, - no need to cut holes under the waterline, doesn't matter if your bilge is dirty. Also, being on the tabs, they are adjustable as to angle, if only a little bit. Price is about $875 a set (4 lights).
- Capt. Mike Holmes
Hurley Lights
For pictures, the sales rep I talked to was Capt. Richard Duncan in Ft. Lauderdale:
duncanrk@bellsouth.net
Users browsing this forum: No registered users and 244 guests
