I am looking for a pair of Michigan Nibral DJX 3 blades 17x15 with medium cup. My shafts are 1 1/8. I will likely have to get 1 1/4 bore wheels and use bore reducers due to lack of availability of 1 1/8.
I have spoken with every prop place around and extensively searched the web.
Do any of the faithful happen to have a pair of these that they want to sell? Either bore size will suffice. Trap season is coming up and if you have boated down here you know there is no way to avoid poly pro trap line. These guys leave 20 to 30 feet of the stuff floating on the surface above the trap. My old bronze Michigan DJ wheels simply can't handle the abuse anymore and come out of rake quite easily despite my attempts to avoid the stuff. Cutters/Spurs are not an option for me.
Other brand Nibral wheel suggestions would also be considered based on your recommendations. I would like to improve cruise speed if at all possible while making the switch.
Nibral DJX 3 blade propellers
Users browsing this forum: Google [Bot] and 226 guests
