Opinion of Fuel Tank
LesBrown
Post by LesBrown »
[iImagemg][imImageg][imImageg][/img][/img][/img][imgImage
][/img]
Here are some pictures of the inside of the tank on our B31. Does the sand box think this tank can be used for diesel. Thanks, Les
Re: Opinion of Fuel Tank
From the images, absolutely, Les...
LesBrown
Post by LesBrown »
Thanks Pat, I felt sure of it but it is nice to know for sure. The renovations are going on at a faster pace Tim had a clean report last check up. He is now motivated to the max. Do you have any templates to cut down the engine stringers to install Cummins?
bob lico
Post by bob lico »
I gave away three sets already, what state are you from?
Les and Tim are just south of San Antonio, Tx... They also build the finest flats boat in Texas and maybe beyond.
bob lico
Post by bob lico »
Nothing that far west.
LesBrown
Post by LesBrown »
The boat has a 170 gallon tank in it now we plan on adding to the top of it to bring it up to around 220 gallons. What are the grounding straps attached to that are inside the tank? Les
Les,
When fueling there's the potential for a static electricity discharge between the pump nozzle and the filling port. The grounding straps are there to rapidly dissipate the charge without a spark. The tank fittings and the fill fitting must be grounded, even for diesel...
LesBrown
Post by LesBrown »
Couldn't we do that externally instead of internally and achieve the same thing? I don't see where the internal straps attach to any thing. Les
Les,
The internal strap should be attached to the fill manifold...
LesBrown
Post by LesBrown »
It was but is it just glassed to the bottom of the tank, that is all that I can see[imImageg][/img]
Les
Mine is grounded at two points. One is the top of the tank right were the fuel fill hose goes into the tank. That should be a bronze port the hose is attached to. The second is at the top at the fuel fitting where the nozzel from the tank goes.
LesBrown
Post by LesBrown »
Tony
All of the external grounds will be reinstalled when we finish the retrofit. What I am talking about in the picture above you can see a flat copper strap laying in the bottom of the tank. These straps were tabbed to the fiberglass of the inside of the tank. The one attached to the fill port is glassed to the bottom of the tank, and the rear one on the fuel outlet and sender port, is tabbed into the side of the tank. I do not understand how this could be any type of grounding. Les
Less
By being in contact with the fuel and grounding to the ports, it is drawing off the static electricity that can build up in the tank.
LesBrown
Post by LesBrown »
Ok I understand now. Les
Users browsing this forum: No registered users and 527 guests
