Hello guys I put a Teleflex system on that was a wall hung now it's a deck mount and the oil fill does not seem to be allowing me to fill it properly.
I get all the air out and no leaks then it starts to slip from air in the system after a short while.
I pulled the decks checked every where no leaks.
steering issue
steering issue
Re: steering issue
It's not unusual for small pockets of air to remain in a steering system for some time even when you do bleed it correctly... Just repeat the bleeding and the bleeding interval should increase and eventually disappear completely... Two to three such "cycles" should see you completely airless...
Users browsing this forum: Bing [Bot] and 117 guests
