Coming together
Coming together
Well while my engines are getting installed i'm finishing up on the hard top,I should be done this week with the top....engines, well weeks hopefully
![Image](http://www.sportfishermen.com/photos/data/500/medium/IMG_6983.JPG)
![Image](http://www.sportfishermen.com/photos/data/500/medium/IMG_6973.JPG)
Re: Coming together
Looking good! Looking very good in fact. Is that a navigation light you built into the top? If so, a close up picture and some additional details would be appreciated...
- matt ciarpella
- Junior Member
Re: Coming together
Jimmy, The top looks good. What core material did you use to get the curve? Been thinking about getting rid of a tower and going with a hard top.
Matt
Matt
Re: Coming together
I used Coosa, 3/4 first, got the radius and then router the channels then glued 1/2 to the top to cap it then router the edges for a bull nose and 60-80 hours later wala
- matt ciarpella
- Junior Member
Re: Coming together
Does it have an arch to it? If so is the coosa board flexible enough to get one?
Re: Coming together
What engines, GSB ,s
Re: Coming together
Matt, yes (i cut groves in the 3/4 but the 1/2" cap i didn't) check out my other post on the hard top I have a slide show of how it was builtmatt ciarpella wrote:Does it have an arch to it? If so is the coosa board flexible enough to get one?
- matt ciarpella
- Junior Member
Re: Coming together
Thanks jimmy
Re: Coming together
Best get a seat belt, I have the 330,s and it's a rocket
Re: Coming together
What kind of numbers (knots) are you getting and what size props/gear ratio…if you don't mindMarlin wrote:Best get a seat belt, I have the 330,s and it's a rocket
- Junior Member
Re: Coming together
JimmyG, I can't find the video you refer to on building the hardtop. Can you point me in the right direction? Thanks
Re: Coming together
- Junior Member
Re: Coming together
Thanks Capt Patrick, JimmyG. Hardtop may be a project I would try.
Users browsing this forum: Sriver43 and 167 guests
