Hello All,
I am preparing for my repower project that I hope will happen sometime this winter and I am trying to do my homework ahead of time. I've made my decision to go with the factory rebuilt Cummins diesels. However, my question/dilema right now is what horsepower to go with. I am repowering from Detroit 453's, so I obviously can deal with a little less speed. Current cruise is abot 17 knots.
I've seen alot of performace data for the 300/330 Cummins and they are impressive. I have not seen as much performance data for the 210's. Can I get a 22 knot cruise with the 210's in the Sportfish model? I like the fact that the 210's don't have aftercoolers (one less thing to break) and should run forever.
My question is, would I be making a mistake not paying for the extra horsepower ? Is the horsepower necessary or just a luxury? I know some of this question is a subjective thing, but, what would you guys do?
Thanks for the input!
Vince
Cummins 210 or 300?
- Vince Luciani
- TailhookTom
Vince - the 210s are just not enough power for the boat. Doubt you could get a 22 kt cruise out of them. My view is that the boats need a minimum of 240 diesel hp a side and a max of 300. I have the 6BTA 250's and the aftercooler is a near zero maintaince item. Look at the reman 270's as middle ground. Those would give you an honest 25 kt cruise and the 300/330 will give you a few knots more, but are a more complex engine. The aftercoolers on the 210 give you 250/270 for free. The Dawn/water wash now and then will keep the aftercoolers in good shape for about 10 cents a side.
I have the 210's on an older (heavy) Sportsfisherman with an even heavier teak deck. I have had them since 1990 after converting from gas and have never been sorry for doing it. The good news is that they are very simple and almost bulletproof. You can use your 1 3/8" shafts. I am underpropped with 20X20 props and cruise an honest 20 kts at 2400 rpm. With the tide, 22.6-23 kts. With 20 x 22's I have no doubt they will meet your needs. The bad news is that the higher hp engines are probably more desireable at resale. 7 gph at cruise per engine is the norm whether there are 2 of you on board, or six. Whatever you do, Good Luck! Walter
- thuddddddd
stuff
Walter, love your avitar.....
Thanks for the research, still no joy though
Thudddd
Thudddd
