I want to run some stuff from the bridge to the top of a half tower. The bundle of wires is too big to conveniently run up the tower leg. So, it will be in a tube/hose/conduit that is affixed to the tower leg.
So, the question is - what tube/hose/conduit? I need about an inch diameter, want it to be water tight, and be UV resistant.
Thanks.
Rigging Tube
Re: Rigging Tube
White spa flex would look best when 1st installed IMO, but it does degrade in the sun. Grey liquidtite conduit is better uv protection, but gives a more industrial look. Both conduits come in nominal tubing sizes, so you can use PVC glue and fittings or compression type bulkhead fittings.
Ray
Ray
1971 Sportfish 314 49 1103
1994 B28 BERF2720L394
Re: Rigging Tube
When I put an instrument box above the flybridge I used PVC pipe, primed and painted, between the flybridge console top and the underside of the box. Cheap, can be glued using epoxy or PVC pipe cement, lightweight, easy to find, and corrosion and rot resistant.
- Tom
Re: Rigging Tube
Can you have Noe weld a "feeder pipe" to the existing structure?
Viva la Presidente!
- Hyena Love
Re: Rigging Tube
Good ideas. Thanks guys.
Tom - I'm trying to avoid a trip to the yard and the all the fun that occurs when dealing with boat yards.
Thanks again.
Thanks again.
Re: Rigging Tube
I went with Black Pool Hose. Comes in 1-1/3" and 1-1/2"
Been on ten years.
Been on ten years.
Users browsing this forum: No registered users and 304 guests
