Fly bridge instment panel
Anybody know where I can get oine? Mine just a piece of plastic or? painted Cummins grey.Didnt last. ...
Wayne
Wayne
I'm not sure if you are looking to replace your Cummins instr panel
(VDO gauges etc). My is aged and only partially working. Tony
Athens has full size Cummins panels for $1100 (new) .
One of these will not fit well on my bridge and you need 2.
I also found this for a panel replacement:
http://www.tadiesels.com/instrument_panel.html
may be of interest but I'm not sure how I would get it to fit nicely.
$550 each.
$550 each.
Wayne - there are a couple of places that have booths at the FLL show each year that make plastic panels you can put your own gagues in. Just send them a template and they cut to your specs, and as I remember it was pretty short money. When my original Cummins plastic panels started going to pot from the sun, one of the Faithful gave me a pair he had where he removed the gagues for a custom install. It was not easy swapping the gagues from the old to the new (pre-CX) but worked fine. I had my canvas guy make a Stamoid cover for the panels that snaps over them and the steering wheel - 4 snaps, removed the screws that hold the outside corners of the panels and put a snap on each one. Works like a champ and the panels will last forever out of the sun.
I purchased black & white plexiglass and quick set glue from a local plastic supplier. After cutting the plexiglass to size I made a black, white, black layup and bevelded the edges and polished to look like a pick guard from a Strat. I targeted out the holes and used a Roto Zip for the tach holes and fostner bits for the other guages and 3 1/4" holes for the LED bilge pump indicator lights. Basic tools are all you need but a router bench helps for the beveling. You could even get fancy and have the boat name engraved if you like.
RussP
RussP
KAHUNA 1963 Sportfish
