Off to get power
Off to get power
Boat left my shop today here is a little slide show...https://www.youtube.com/watch?v=iaf7AAA ... e=youtu.be
Re: Off to get power
Incredible. She looks great.
Perfection... And, as soon as you'll put the power in it will be purrfection :-)
Boat looks great what cummins engine did you decide on?
Thanks everyone, Bob it's at Forked River Diesel getting Cummins QSB 380's and if that is to much we will de-tune accordantly 355,330 or 305 evidently it's just a few keystrokes on the computer and you dial in your hp
Do you still have the oem shaft logs in the boat and are you open to F/G shaft log and reduced shaft angle to utilize 380hp along with specialize props
Bob shaft logs are out and the bedding area ground out waiting to glass in tubes, that is as far as I can go until engine angles are establishedbob lico wrote:Do you still have the oem shaft logs in the boat and are you open to F/G shaft log and reduced shaft angle to utilize 380hp along with specialize props
- MarkS
Really gorgeous!
There is something missing here! You are the one to tell the installer " this is NOT a normal installation you want to slide a nickel under the drain plug of the ZF transmission and that is the total clearance from bilge. You will have to tilt struct with shim to creat new shaft angle.
Users browsing this forum: No registered users and 90 guests
