Bolts for battery cables
OK, I got new battery cables and new batteries. Now, what kind of bolt should I use? The size would be 3/8 or M10. That's not what I'm asking. My question is what material the bolts should be made of...
Stainless (marine preferably) makes sense... But so does copper (better conductor)... And where can I find these?!...
Re: Bolts for battery cables
Nav,
Are you refering to a cross bolt or top bolt that locks the lead cable end to the lead battery post?
If so, it really doesn't matter since it's two clean and matching lead surfaces mated together that carries your current flow. The bolt only locks down the connection. any steel bolt will carry current pretty much equally as long as it's clean and not issolated.
Correct...CaptPatrick wrote:Are you refering to a cross bolt or top bolt that locks the lead cable end to the lead battery post?
If I understand you correctly you're saying the current will go from the (lead) post, through the (tinned) copper lug into the (tinned) copper wire and the function of the fastener is simply to hold the lug against the post?!... I guess that makes sense... Seeing as current runs on the surface of the conductor...CaptPatrick wrote:If so, it really doesn't matter since it's two clean and matching lead surfaces mated together that carries your current flow. The bolt only locks down the connection. any steel bolt will carry current pretty much equally as long as it's clean and not issolated.
Pat: I always use stainless to prevent corrosion on the threads if any vapors leak out. Any reason not to? It has worked fine for me for years.
Rawleigh,
I agree, stainless is the way to go. My comment to Nav was that the bolt isn't the current carrier....
Suggestions for vendors of marine SS bolts, nuts and so forth?!...
Boltdepot.com serves me well, and they are suited to small or large orders if you have no local supply house you can walk in for,
Preston Burrows
1976 B28 FBC
BERF1398M76J-285
1976 B28 FBC
BERF1398M76J-285
I probably have several (this area is allegedly the boating capital of the state, nation and possible the world) but I'd be looking for marine SS (as opposed to "regular" SS) hardware and every place I've been to so far says ("regular") SS...Preston Burrows wrote:Boltdepot.com serves me well, and they are suited to small or large orders if you have no local supply house you can walk in for,
I'm starting to believe that nobody makes that stuff out of marine SS...
316 SS bolts from Amazon
Be sure to notice the "Currently Showing 20 of 108 sizes Show All" Click Show All to see larger sizes... They go all the way to 1/2"-13 x 8".
Users browsing this forum: Bing [Bot], Tommy and 295 guests
