bonding
- Russ Pagels
bonding
I'm in the process of re- bonding the boat. what are the latest color as per regs, yellow,green ? thanks russ
1972 31 FBC 315-141-1226
is that good men do nothing.
- Russ Pagels
Re: bonding
Thanks Pat, checks in mail.do we get oak leaf clusters for every year. Russ
Re: bonding
Good idea, Russ... I'll look into the graphic requirements.do we get oak leaf clusters for every year
- TailhookTom
Re: bonding
Thank God that was a question about wiring -- I thought for a minute someone wanted to hold hands and sing Kumbaya and we know the mean team would have had to become, well, mean.
Tom
Tom
Re: bonding
Exactly my thought as I saw the title of the thread.......
- TailhookTom
Re: bonding
mike ohlstein wrote:Exactly my thought as I saw the title of the thread.......
I'm almost ready for a mean team battlefield promotion. I'm feeling since the roads here at slushy, muddy and plain crap, perhaps some splashed young children with their grandmothers in tow might put me over the top?
Tom
Re: bonding
I'm about to go take the plow and plow in some parking spaces that have been cleared into the street...
Re: bonding
Russ Pagels,
The color is green and the wire size is #8 AWG tinned copper wire, use heat shrinked round captive lugs for all connection points, you might have to re-solder drops back onto the old flat copper bonding strip that is attached to the outside portion of the inboard stringers(along the outside of the fuel tank areas you will see the old strip. Everything that is in contact with salt water must be bonded, including engines, panel boards, shaft logs, etc. All leeds should end up at a central bonding point on the boat, such as a transom zinc or a dyna plate. You can check the ABYC standards under section E-11 electrical.
- Russ Pagels
Re: bonding
Thanks Pete, as usual great information. Good luck on your up coming operation. Russ
Users browsing this forum: No registered users and 365 guests
