Topside progress
PeterPalmieri wrote:Sim,
Your the expert do you think a 2x2 1/2" plate through bolted is sufficient?
No expert here, I just play one on TV.
The plate will handle it, just need to make sure your deck will.
Mine was a covered plywood deck with a rear center hatch too close to give adequate support of a chair in my opinion. Your sandwiched ply with teak deck. If that in good shape you should be good.
That Chair is going to look real sharp in that cockpit!
PeterPalmieri wrote:Bookmark this for myself
http://www.bertram31.com/proj/tips/pedistal.htm
Thanks Cap!
Peter,
Keep in mind that the size of your backing plate should be the largest that you can manage to fit in. The larger the plate the more area that the forces will be spred over. As surface area increases, pound per square inch of force decreases...
PeterPalmieri
Post by PeterPalmieri »
The subfloor under the teak deck is 3/4 ply, the section under the existing plate is 2 pieces of 3/4" ply with 1/4 aluminum plate that is tied into the deck supports. Going to have Raybo install the pedestal, my biggest concern is filling the existing holes to not allow water into the deck. Next time the deck has to come up I'll have a top plate made for easy removal of the pedestal.
The chair cleaned up very nicely with just a few small dings in the fiberglass seat..
PeterPalmieri
Rob at Raybo sent these photos over on Saturday, the boat has been primed. Looks great so far.....
mike ohlstein
Post by mike ohlstein »
Ah, my old teak deck. How did you come by it?
Mean Team Leader
PREDATOR
Burn Oil
Eat Food
1973 FBC 1286 0273-315
PeterPalmieri
That's your teak deck?
Prior owner installed it around 2008 I believe he put it in new but your saying different?
mike ohlstein
Looks like it, but I would have to look closer.
Mean Team Leader
PREDATOR
Burn Oil
Eat Food
PeterPalmieri
Here is a better pic Mike
mike ohlstein
Ahh. No, not mine.
Mean Team Leader
PREDATOR
Burn Oil
Eat Food
JP Dalik
Post by JP Dalik »
Looks nice Peter Big improvement.
Did you go with manual pop ups on the bow deck?
You look to be on the right path
PeterPalmieri
JP,
10" gemlux pull ups in the bow and the slim version of the same cleat mid ship.
Brian Y
Post by Brian Y »
The boat is looking great! I am very jealous of the teak deck. To me: that is the difference between a real fishing boat and a toy... Great job! Can't wait to see it after the top coat.
Brian
PeterPalmieri
I love the teak deck as well, that's pretty much what sold me on this particular boat. Hoping to stop down at Raybo tomorrow or Friday morning to take a look and see where we're at. Next step was non skid and then installing the hardware. Shouldn't be to long now.
Users browsing this forum: Bing [Bot] and 417 guests
