repower
Stephan
Re: repower
Post by Stephan »
bob lico wrote:terrible installation you better PM me before going on. why did you not go with ZF IRM 220A -----10 degree down angle!!!!!!!!!!!!!!!!!!!!
Jeez for a moment there I had my Lico translator off and misunderstood your message to be critical of my friend Tom and not your generous and experienced self offering to help....
I must be spending too much time on those other boat boards.
Best,
Stephan
bob lico
Re: repower
Post by bob lico »
tom is my friend also thats why i am trying to help him.i been so busy lately i negleted to advise tom.
JP Dalik
Re: repower
Post by JP Dalik »
Why a 220a when the horsepower is t even 250. Looks like a 210 cummins maybe 250 at best without tombstone air cooler. Gonna be a 23kt cruise boat maybe use big acme or dqx 3 blades. Why all the hate speedy man.
bob lico
Re: repower
Post by bob lico »
jp i am communicating with tom by pm. the differance between the ZF 63 and 220 irm is not a hp issue with this cummins 220hp installation .the problem is 2 degree differance in down angle because it is essential although differcult in a 31 bertram/cummins installation to keep the cummins as close to level as possible it is essential or number 1 cylinder will cook especially if build date is prior to 2004 (storm block) with small injectors,rotating exhaust valves,scuff resistant pistons,reshaped combustion chamber all redesign in the aftermath of cpl 970 days .i cannot watch a brother destroy a pair of engines especially when i knew better thats not with this board is all about.
bob lico
Re: repower
Post by bob lico »
tom batteries in companion way centered and on bilge as low as possible like this
bob lico
Re: repower
Post by bob lico »
10 degrees shaft angle with altered struct. note after filling gap on top of struct make contour around front pad of struct (faired)
bob lico
Re: repower
Post by bob lico »
tom after shaft coupling only 4" of shaft showing with 220 irm and engines pull back as far as possible with up and over exhaust insulation on port touching engine cover!
Re: repower
Post by 1962 31 »
just ordered fiberglass logs and pss seals more grinding tonight !!!!!!!
what should I use for bolts to mount the strut? stainless? silicone bronze ?
Re: repower
silicone bronze...
Re: repower
Post by 1962 31 »
progress update
shaft logs are in just need final fairing
strut pads are in and done
second motor is all together and will be at the boat in next few days
raw water pickups are in
new control cables are in and brackets made for throttle on the motor side
redid fuel fill and vent hoses
all new motor mounts
pss dripless seals waiting to go in
fuel filters mounted and plumbed
going to make surge tubes do I need a special resin or will epoxy resin be ok for connection at the Y so to speak
Re: repower
Tom,
No! Epoxy won't take the heat of an exhaust system. Use either polyester or Vinylester resin for any construction that has to handle exhaust heat...
Re: repower
Post by 1962 31 »
roger that
I have vinylester at the shop also ill use that
bob lico
Re: repower
Post by bob lico »
tom did you go up and over placing the sprinkler head in the perfect vertical position for even cooling water distribution(no hot spots)?
Re: repower
Post by Yannis »
CaptPatrick wrote:silicone bronze...
Excuse me, but what is silicone bronze?
Captain Pat, who has to come and what is there to take ? !!!
Re: repower
a bronze with 2-3% silicon that is resistant to corrosion
Anybody who wants my guns... Originally made famous by King Leonidas I -- Applied today in the US by many second amendment supporters.
Re: repower
All bronze marine fittings, especially those in contact with Sea Water should be silicon bronze.
Re: repower
Post by 1962 31 »
bob surge tubes and flaps for now this stuff is getting expensive lol
I had 90 percent of the stuff to do the exhaust ill build up and over next winter
on the shower head end of yours are there holes built in like the factory ones or does it just have an open cone
I cant find any pics of that end of the shower head on anyone's builds
Joseph Fikentscher
Re: repower
Post by Joseph Fikentscher »
bob lico
Re: repower
Post by bob lico »
my sprinkler head has same holes as the Cummins OEM. 90 degree part. i went to the maximum height in engine compartment and then vertically straight down so cooling water is applied in a perfect circle to cool exhaust .this being said will last a hundred years and together with one way cone in muffler makes a surge tube totally useless.on a every times basis i run on one motor while offshore .i have try every way i could to slug a motor including backing down at excessive speed to put water over transom never happening trust me quite a bit of through went into the entire exhaust---------000000000 back pressure but thats another story.
bob lico
Re: repower
Post by bob lico »
surge tubes would ruin the hold design of engine layout. port side has generator as partial counterweight the starboard has holding tank,gin pole support. those surge would take up precious space adjacent to engines and most important lose 10 hp .the mini mac mufflers shapes the outgoing exhaust in a circle around water flow so as not to impede exhaust but still get 1000percent surge protection.
Re: repower
Post by Yannis »
Has this motor ever run ?
bob lico
Re: repower
Post by bob lico »
nine years straight with 0 down time .block heaters keep engines like new 24/7 . no condensation in engine compartment always warm to touch.
Navatech
Re: repower
Post by Navatech »
bob lico wrote:nine years straight with 0 down time .block heaters keep engines like new 24/7 . no condensation in engine compartment always warm to touch.
I think Yannis was giving you an oblique compliment... As in that engine looks so good it looks pristine... I.e. never run...
Re: repower
Bob
Who makes a one way cone in muffler
bob lico
Re: repower
Post by bob lico »
oh boy tony you are asking a major secret ,but for you anything.remember a little edge here and another edge here is how this boat has incredible fuel economy or speed if you want that instead. muffler is made by Centek inc. Minimax 1050600 a 6" inlet and 6" outlet 25" long and 10.04 in diameter.one way muffler because reverse cone is on inlet side.photo of installation under deck along outside 2" from hull side along stringer.
Re: repower
Bob
Thank You
bob lico
Re: repower
Post by bob lico »
oh yea tony that photo also illustrates the 10 degree shaft template------------oops
neil
Re: repower
Post by neil »
Bob please give me a call thanks
Re: repower
bob lico wrote:oh yea tony that photo also illustrates the 10 degree shaft template------------oops
Bob
Looks like Bertram took a page from your book for the 35. 10 degree shaft angle and a 22 degree deadrise.
Re: repower
Post by 1962 31 »
getting closer
Re: repower
Tom
Looks like you are moving along.
If you have not replaced that bulkhead behind the engines, you might want to thing about it, or if it is in good shape, I would glass it in well.
Users browsing this forum: No registered users and 109 guests
