It's not the block that gets rebuild but rather the whole engine... Rebuilding an engine is NOT a specific term and many people understand it to mean different things... At the low end it means a partial overhaul... At the high end the engine is fully brought back to OEM specifications...jspiezio wrote:Another question. How would the old block be rebuilt that makes it so expensive versus a replacement block.
YANMAR 6-LPE-STE
Re: YANMAR 6-LPE-STE
cam/ bearings /2 pistons oversized--- valves-- he lost me @ 29,000
Sorry to hear about your engine problem. I don't understand why it is so expensive or almost the same price as a new one.
Killa,
Brewsters boat is for sale in the low to mid $30's with a pair of the 6LP's. You could sell of the other engine and transmissions and save some coin.
Jspiezio,
There were two 4LH failures on the same type of hose that I heard of. My fix was to have Morland Hose in Oakdale make up a new set. Cheap money and a quick install.
Harry
Jspiezio,
Harry
killa,
I called my Jersey engine go-to guy and he has a used 6LP-STE for sale. Call Kenny King at 908-513-4577. I still like the idea of parting-out Brewster's boat.
Harry
Harry
Exactly where is this braided line is that you all speak of?
will take pic and post it .I recived another piece of info for any yanmar owners .When I dropped back on the rpm from anything over 3000 right down to 1000 & below the motor would rap for 3 to 5 sec & go right away.Should have had valve guides checked that is a problem with the ste model there was a class action suit and I believe never amounted to anything.As far as the noise denial will get you a blown motor
That would be appreciated Killakilla wrote:will take pic and post it .I recived another piece of info for any yanmar owners .When I dropped back on the rpm from anything over 3000 right down to 1000 & below the motor would rap for 3 to 5 sec & go right away.Should have had valve guides checked that is a problem with the ste model there was a class action suit and I believe never amounted to anything.As far as the noise denial will get you a blown motor
Users browsing this forum: Google [Bot] and 414 guests
